Help with PKU-MIT on Evo 9
I have send some much time trying to program this thing bypass for my remote start.
here is what says in the progmamming instructions.
1. insert first original key (ignition on for 5 sec)
2. insert second oem key (ignition on for 7 sec)
3. Jum power to accessory wire.( which I do then then they immo flashes)
4.PKU-MIT programmed.
Seems like ijjust cant get this darn thing to program.
Does anybody have any better instructions on how this programming gets done?
Please help.
Please help.
I think it is acc to on several times and the second key same thing like you would program another key and put the PKU-MIT close to the key. the PKU-MIT can only be programmed once, once you mess up you need another PKU-MIT. read the instructions carefully.
bbak11010
Mar 31, 2013 06:11 PM
