Remote start - do I need a spare key?
Old Dec 14, 2011 | 07:08 AM
evopwned's Avatar
I wouldn't be surprised if Best Buy charges you $200 or more.
Old Dec 14, 2011 | 10:44 PM
MitsuOZ's Avatar
Originally Posted by Marcac
I am a Best Buy installer and we ARE allowed to install certain Remote starts onto manual transmission vehicles, but only the Viper alarms that we sell that have a manual mode. When installed properly the secquence is; Arrive at your destination. Push the brake, pull the e-brake release the brake, push the remote start button on the key fob, take your key out of the ignition (the car stays running), get out of the car, Push the lock button on your remote, this locks the doors and turns off the car. This sequence guarantees that the car is in neutral, if you even open a door before you remote start, you have to repeat the entire sequece. Let me know if you have any other questions as I do these alot.
As he says, I've installed a bunch of these on evo's particularly the 5901, but i've always left them in automatic mode since one small thing will disable the remote start until you redo those steps again(i.e. alarm goes off, door opens .. ect) if your prone to leave your car in gear, then my advice is don't get a remote start.
Old Dec 18, 2011 | 09:28 AM
NattyMyst1c's Avatar
Originally Posted by Tevo9K
quick question.. i was going to put an auto start on my evo.. but my friend at the shop refuses to put one on cuz he's had people put it in gear when its off and accidentally hit the start button and the car has taken off and plowed into houses and etc...
i myself haven't heard or seen that before.. so is that true??
and if it is.. is there any way to keep that from happening besides just keeping it off of gear??
i never keep my car in gear in general but ive heard the same thing and had the same situation, refused to put it in for peoples cars taking out houses. some people will put them in for you, atleast near me, i think others just dont want to have it be their fault if something did happen.
also, im pretty sure viper or another company makes a special kit for manual autostart for a sequence where to you the car off and an alarm goes off that makes you put the car in neutral and pull the ebrake with some other stuff inbetween.. not 100% sure but definitely worth looking up.
i want autostart too since i always warm my car up in the morning it wont be so bad and i wont have to worry about someone stealing my car at work.
Old Dec 22, 2011 | 01:15 AM
jdmk1dd's Avatar
Going through the same process here with the 5901 but I can't seem to get the starter to work on the remote start ??
Old Dec 26, 2011 | 10:58 AM
agentq's Avatar
best buy did a viper autostart in my 04 raliiart no spare key required, but a local shop did a compustar alarm/autostart in my 06 evo 9 mr and it needed a spare key, little under 100 bucks from the stealership
Old Dec 26, 2011 | 06:12 PM
mrb00st's Avatar
in the couple evo's ive installed remote starts in. i have always disabled the imob in the ecu. another way to do it if u dont wanna spend 100 for another key. is you get a razor blade and cut around the outside of the key, taking the chip out. for there on you only need $1 keys. yes i know it deletes the point of having the key, but some times ppl dont wanna pay 100+ for another key on top of the price im charging them to do a remote start.
also, and 08+ evo fortin makes a bypass that works doorlock, triggers, and you dont have to give up a key.
Old Dec 27, 2011 | 03:40 AM
Biggiesacks's Avatar
not having a spare key to begin with, i also disabled the immobilizer in the ECU. No spare key required.
Old Dec 27, 2011 | 06:19 AM
jdmk1dd's Avatar
Have you had trouble installing the ignition,starter and accessory wire ?? Cuz when I did mines it gives out a buzz which doesn't sound right
Old Dec 27, 2011 | 06:44 AM
mrb00st's Avatar
the brain buzz's? check 12v and check ur ground at the brain, not at the connections
Old Jan 2, 2012 | 02:52 PM
srtdave's Avatar
i have the viper 5901 in my 9 with the imob. disabled via ecuflash and setup in automatic mode so i dont have to go through the bs steps and if one of my kids opens door and ruins the wholel process it doesnt concern me leaving it in gear i just installed a valet button when i stop the car press the button and the 5901's turbo timer takes over runs for a minute and shuts down. So i guess my advice is use the turbo timer feature then you know its out of gear every time, if not as soon as you go to get out of car when the cars stalls you will remember.
Old Jan 3, 2012 | 04:07 PM
jdmk1dd's Avatar
I have a spare key for the Immobilizers transponder bypass n I have a Greddy turbotimer n I can leave it in auto mode so I don't have to go through the steps right?? I just have trouble connecting the red,pink, n green wires for the auto start am I missing something??
Old Jan 16, 2012 | 10:40 AM
degin219's Avatar
you guys don't need a spare key, all you need is a bypass. You wire it up and i takes the "code" a key puts out and will only activate when you remote start. Best buy will charge you if you dont bring your own alarm any where from 120-240 depends on alarm kind or if its just a remote start.
You can buy one from them and "basic" install is included but you still have to pay $30 to have the bypass installed and another $30 for a clutch bypass, plus the parts for that and thats $10.
http://www.ebay.com/itm/Xpress-Kit-T...ht_1650wt_1211
experience: 2 years best buy installer
Old Jan 16, 2012 | 11:52 AM
Vivid Racing's Avatar
Directed Electronics (makers of Viper, Hornet, and most other nice alarms) offer a remote start module for manual transmission. If you're installer is unaware of it, then he shouldn't be touching your car in my opinion.
Another option is to use the handbrake as an input instead of the park position that would be used on an autotragic car. That way the handbrake has to be up for the remote start to work.
Ancyker
22
Apr 4, 2016 04:58 PM
evoniners
11
Oct 11, 2015 10:51 AM
RA012124
Outlander Sport
Jul 26, 2014 11:55 AM
pinegreen
15
Jul 25, 2014 04:28 PM
damoevo8
Australian Forum
Jan 10, 2013 04:22 PM
