help please electrical....
it is the connector under the kick panel that you remove. it's the c-129 connector. right above the black connector. it should be pin 22 which is next to the brown wire i think it was blue yellow. i'll make sure later. that was corroded and the pin it self was shorting out.
basically if you go here
https://www.evolutionm.net/forums/ev...s-how-fix.html
that's pretty much what's going on.
Mine wasn't corroded, but I'm going to put a multimeter on it and see if it's getting power, otherwise I guess I'll pull my radio out and look back there.
jzapatajr
17
Jun 2, 2020 06:44 PM
mrm95
Jul 29, 2015 05:06 PM
bboypuertoroc
11
Jul 5, 2011 05:21 AM
