Evo 8 Speedo Needle Sticking/lazy????
My Evo 8s speedo needle is sticking/being lazy, I have to keep tapping the clocks for the needle to jump to the correct speed.
For example I will be slowly accelrating from 30mph up to 40mph and the needle doesn't move off 30mph unless I tap the clocks. Same happens at any slow acceleating speed. And also happens when decelerating. I will decelarate to 0mph and the needle will stop at 20mph then 2 seconds later just fall to 0mph.
Works fine accelerating fast when i plant it. But normal driving it just acts up.
Has anyone any idea of what could be causing this problem? Evo 8 FQ330 Ralliart
Cheers
Cheers
But dont make a move on ordering a new cluster based on my notes. Search the forum for similar threads. Im sure this is not the first case of this issue
On my Mitsu oil temp issue, there were a few threads confirming this issue
Edit: Heres a post that no one answered noted the same issue (its an FQ as well but doubt that makes a diff)
https://www.evolutionm.net/forums/ev...-sticking.html
I also have UK EVO 8 FQ-330 and my speedometer needle will just drop from 20 mph straight to 0 mph. Did you manage to get anywhere with yours.
I don't ever remember it being this way the past 5 years but I took it out of storage this weekend and now notice it.
