Evo 6 (VI) ECU into a Evo 4 (IV)
Hey guys First Thread here! And yes I did Google and I didn't find a solution, So my ECU gave up on me on my Evo 4 so I got my self a Evo 6 ECU but there are a few issues that I have run into. Yes it was Direct plug in and started right up so the issues are-
1. The Radiator Fan turns on as soon as I put the key to Ignition (when engine is cold) I tried the ecu in my friends Evo 4 and the same thing happened why is that and how do I turn it off so it only comes on when its needed.
2. I'm getting a CEL (engine light is on ) when I plugged the scanner it says Diagnosing O2 Sensor Heater Circuit error shows up how do I get tid of this because I did clear it and it comes back.
3. I heard that the alternator won't charge since a wire has to be snipped I will check this tomorrow and see if its charging if it isn't what should I snip ?
Thank you in advance.
I don't mean to dissuade you, but EvoM is not the best place to ask this question, since it's a US-centric site and there are very, very few Evo 4-6s there. You won't find many people with experience in this and you could wait a long time for an answer. For anything Evo 4-7, I would suggest you visit the Lancer Register forum, they handle stuff like this routinely.
z32cctx
Feb 14, 2012 08:28 AM
EVOConnection
Feb 4, 2004 02:00 PM
