DIY: Viper 5701 Install on CT9A
I thought this might be useful to some people interested in installing vipers new 5701 alarm.
http://www.drdetailshop.com/Viper5701Boxmed.gif What I like about this alarm system 2 remotes - Super slim design (One 5-Button 2-way, One 5-Button 1-way) Antenna with Integrated LED and Switch SilentMode2 Sirenless Modes Virtual Tach Defroster Output w/ Dedicated Channel Smart Start (start car based on temp/timer/voltage) Auto Temp Display on Remote Cabin Temperature Request Onboard Shock Sensor (shock sensor is inside main unit Stinger DoubleGuard ) 4 Aux Outputs 2,000 feet FCC legal 2-way range The best thing about this is the protection it provides for remote starting the vehicle. It has a very good check system to make sure the car is in neutral before going into the remote start mode. The only way to have it remote start is if someone sneaks into your vehicle without triggering the alarm and physically leaves it in gear. Or if you leave someone in the vehicle while arming and they put it in gear. Additional Items needed for purchase -SPDT Relay with socket harness Okay now onto the wiring... - Unlike previous viper models the heavy guage ignition harness is a little bit trickier due to the flex relay added into this unit, but just follow my ignition wiring below and you should be okay. - If you open the compartment inside the brain unit you see that there is a spot for a 10amp mini bus fuse. This has to be hooked up for a positive polarity pg.55 of install manual The ignition wires consist of these wires Function ------- polarity----------------Vehicle Wire Constant------------ + -------------------- white Ignition-------------- + -------------------- blk/wht Accessory----------- + --------------------- blu/wht Accessory 2--------- + ---------------------- blu/blk Starter--------------- + ---------------------- blk/yel Harness #3 all located in ignition black plug Function--------------------------------------- alarm wire---------------------vehicle wire (+)Ignition 1Input/ouput ----------------------- pink -------------------------- blk/wht (30a Fused Igntion 2/ Flex relay Input 87--- red/wht------------------------- wht Accessory Output----------------------------------orange--------------------------blu/wht (+) Starter Output (car side starter kill wire)---violet--------------------------blk/yel (S) (+) Starter Input (key side starter Kill wire)---green-------------------------blk/yel (k) (+)fused(30a) Ignition Input-----------------------red----------------------------wht (+)Ignition 2/Flex Relay Output-------------------pnk/wht----------------------blu/blk Flex Relay input 87a key side(if req) of Flx Relay--pink/blk-------------------not connected Fused (30A) Accessory/Starter Input---------------red/blk---------------------wht Harness #1 Function--------------------------------------- alarm wire---------------------vehicle wire--------------------location Trunk release for after market solenoid----RED/WHITE----------------------need to wire to relay for aftermarket solenoid power for alarm system------------------------RED------------------------------wht------------------------------ign harness siren output-------------------------------------BROWN-------------------------red wire on siren---------------siren lead not used --------------------------------------- WHITE/BROWN----------------not used--------------------------not used alarm ground ----------------------------------BLACK---------------------------chasis------------------------------ground not used ----------------------------------VIOLET--------------------------not used--------------------------not used trunk trigger -----------------------------------BLUE-----------------------------green/orange------------------trunk Door Trigger Input ---------------------------Green-----------------------------blue-------------------------------Instrument cluster Blue plug DOME LIGHT OUTPUT------------------------BLACK/WHITE -------------------?------------------------------------? not used -------------------------------------- WHITE/BLUE ---------------------not used-------------------------not used PARKING LIGHT OUTPUT---------------------WHITE----------------------------green/white----------------------door kick panel not used ---------------------------------------ORANGE--------------------------not used--------------------------not used Harness #2 not used Door Lock Harness Function--------------------------------------- alarm wire---------------------vehicle wire--------------------location UNLOCK OUTPUT---------------------------------Blue-----------------------------light green --------------------door kick panel LOCK OUTPUT-------------------------------------Green--------------------------violet ---------------------------door kick panel Remote Start Input Function--------------------------------------- alarm wire---------------------vehicle wire--------------------location NEUTRAL SAFETY SWITCH INPUT--------------BLACK/WHITE---------------Blue/Red-------------------------Instrument cluster blue plug TACHOMETER INPUT WIRE----------------------VIOLET/WHITE--------------Green----------------------------Instrument cluster white plug BRAKE SHUTDOWN WIRE ---------------------- BROWN------------------------ Green-------------------------Door Kick Panel HOOD PIN SWITCH INPUT --------------------- GRAY --------------------------Lead from Hood Pin --------Installed hood Pin switch in Hood REAR DEFOGGER -------------------------------- BLUE/WHITE -----------------White/Black------------------Climate control plug at switch Remote Start Ouput Function--------------------------------------- alarm wire---------------------vehicle wire--------------------location not used -----------------------------------------PINK/WHITE--------------------not used------------------------not used not used -----------------------------------------ORANGE-------------------------not used------------------------not used Output to clutch bypass ----------------------VIOLET--------------------------clutch switch behind clutch pedal (must be hooked to SPDT relay) not used -----------------------------------------PINK -----------------------------not used-----------------------not used not used -----------------------------------------BLUE -----------------------------not used-----------------------not used When splicing wires, In my opinion this is the best way to do it. http://www.mmxpress.com/technical/images/14.gif Then split the wire threading through the loop and wrap it around the corresponding side fo the split wire, solder then high quality electrical tape. ....will update later with remaining instructions |
Remote Start Input
Function--------------------------------------- alarm wire---------------------vehicle wire--------------------location NEUTRAL SAFETY SWITCH INPUT--------------BLACK/WHITE---------------Blue/Red-------------------------Instrument cluster blue plug This actually exists/functions in an evo? |
Originally Posted by biggie5252
(Post 6019077)
Remote Start Input
Yeah, I was hoping to get around all that and just use an NSS. I leave the car in neutral anyways, I was just wanting a backup incase it wasn't in neutral for whatever reason.
What does it sound like, does it sound like the alarm system on a super car?
^^ just the standard tone on all DEI alarms.. I bought it more for the remote start safety feature..
johnjonfenomeno,
On a scale of 1-10, how would to rate ease of install of the 5701?
Originally Posted by johnjonfenomeno
(Post 6016781)
http://www.drdetailshop.com/Viper5701Boxmed.gif What I like about this alarm system 2 remotes - Super slim design (One 5-Button 2-way, One 5-Button 1-way) Antenna with Integrated LED and Switch SilentMode2 Sirenless Modes Virtual Tach Defroster Output w/ Dedicated Channel Smart Start (start car based on temp/timer/voltage) Auto Temp Display on Remote Cabin Temperature Request Onboard Shock Sensor (shock sensor is inside main unit Stinger DoubleGuard ) 4 Aux Outputs 2,000 feet FCC legal 2-way range The best thing about this is the protection it provides for remote starting the vehicle. It has a very good check system to make sure the car is in neutral before going into the remote start mode. The only way to have it remote start is if someone sneaks into your vehicle without triggering the alarm and physically leaves it in gear. Or if you leave someone in the vehicle while arming and they put it in gear. Additional Items needed for purchase -SPDT Relay with socket harness Okay now onto the wiring... - Unlike previous viper models the heavy guage ignition harness is a little bit trickier due to the flex relay added into this unit, but just follow my ignition wiring below and you should be okay. - If you open the compartment inside the brain unit you see that there is a spot for a 10amp mini bus fuse. This has to be hooked up for a positive polarity pg.55 of install manual The ignition wires consist of these wires Function ------- polarity----------------Vehicle Wire Constant------------ + -------------------- white Ignition-------------- + -------------------- blk/wht Accessory----------- + --------------------- blu/wht Accessory 2--------- + ---------------------- blu/blk Starter--------------- + ---------------------- blk/yel Harness #3 all located in ignition black plug Function--------------------------------------- alarm wire---------------------vehicle wire (+)Ignition 1Input/ouput ----------------------- pink -------------------------- blk/wht (30a Fused Igntion 2/ Flex relay Input 87--- red/wht------------------------- wht Accessory Output----------------------------------orange--------------------------blu/wht (+) Starter Output (car side starter kill wire)---violet--------------------------blk/yel (S) (+) Starter Input (key side starter Kill wire)---green-------------------------blk/yel (k) (+)fused(30a) Ignition Input-----------------------red----------------------------wht (+)Ignition 2/Flex Relay Output-------------------pnk/wht----------------------blu/blk Flex Relay input 87a key side(if req) of Flx Relay--pink/blk-------------------not connected Fused (30A) Accessory/Starter Input---------------red/blk---------------------wht Harness #1 Function--------------------------------------- alarm wire---------------------vehicle wire--------------------location Trunk release for after market solenoid----RED/WHITE----------------------need to wire to relay for aftermarket solenoid power for alarm system------------------------RED------------------------------wht------------------------------ign harness siren output-------------------------------------BROWN-------------------------red wire on siren---------------siren lead not used --------------------------------------- WHITE/BROWN----------------not used--------------------------not used alarm ground ----------------------------------BLACK---------------------------chasis------------------------------ground not used ----------------------------------VIOLET--------------------------not used--------------------------not used trunk trigger -----------------------------------BLUE-----------------------------green/orange------------------trunk Door Trigger Input ---------------------------Green-----------------------------blue-------------------------------Instrument cluster Blue plug DOME LIGHT OUTPUT------------------------BLACK/WHITE -------------------?------------------------------------? not used -------------------------------------- WHITE/BLUE ---------------------not used-------------------------not used PARKING LIGHT OUTPUT---------------------WHITE----------------------------green/white----------------------door kick panel not used ---------------------------------------ORANGE--------------------------not used--------------------------not used Harness #2 not used Door Lock Harness Function--------------------------------------- alarm wire---------------------vehicle wire--------------------location UNLOCK OUTPUT---------------------------------Blue-----------------------------light green --------------------door kick panel LOCK OUTPUT-------------------------------------Green--------------------------violet ---------------------------door kick panel Remote Start Input Function--------------------------------------- alarm wire---------------------vehicle wire--------------------location NEUTRAL SAFETY SWITCH INPUT--------------BLACK/WHITE---------------Blue/Red-------------------------Instrument cluster blue plug TACHOMETER INPUT WIRE----------------------VIOLET/WHITE--------------Green----------------------------Instrument cluster white plug BRAKE SHUTDOWN WIRE ---------------------- BROWN------------------------ Green-------------------------Door Kick Panel HOOD PIN SWITCH INPUT --------------------- GRAY --------------------------Lead from Hood Pin --------Installed hood Pin switch in Hood REAR DEFOGGER -------------------------------- BLUE/WHITE -----------------White/Black------------------Climate control plug at switch Remote Start Ouput Function--------------------------------------- alarm wire---------------------vehicle wire--------------------location not used -----------------------------------------PINK/WHITE--------------------not used------------------------not used not used -----------------------------------------ORANGE-------------------------not used------------------------not used Output to clutch bypass ----------------------VIOLET--------------------------clutch switch behind clutch pedal (must be hooked to SPDT relay) not used -----------------------------------------PINK -----------------------------not used-----------------------not used not used -----------------------------------------BLUE -----------------------------not used-----------------------not used ....will update later with remaining instructions |
If you follow the above mentioned wire by wire guide .. its a walk in the park .. Ive done the figuring out for you.. Shops charge 700 installed for this. Go on ebay and get one for 250 shipped. Then follow the above
Sounds good! Thanks 4 your time and info!
(Post 6062634)
Originally Posted by RUDEBOY77
(Post 6063640)
This alarm is the best investment I've made to my Evo. Good choice!
(Post 6063985)
Might I add, One thing I did not have to do was get an immobilizer bypass (DEI 556U) since i used a standalone ecu. If you are still on the stock ECU you will need this along with a spare key.
Originally Posted by Dennis F
(Post 6064611)
This is not intended for a 5 or 6 speed car. This is actually a circuit for automatics for the neutral safety switch.
Unless DEI changed their programming of this circuit, it is not intended for anything else other then an automatic. Yes DEI changed their programming with it.. The alarm can be set in manual or auto mode.. If in manual mode the alarm will use this as a part of the input in its neutral safety check sequence..{thumbup} |
Question about the install: How were you taping into the factory wires? Solder or plastic taps? lastly, where did hide the alarm brain?
