defi egt problem
i have a defi egt gauge and it seems to be on the way out
now all it does is stay on 6 bar nomatter how hot is gets it does move a little bit but always stays around 6 or 6.5 bar do u think its the sensor or the defi link |
sounds like it. Red light isnt flashing is it? Have you check all ur wiring connectors?
the light is flashing so i know its getting power
If the connection is under hood, check for corrosion on the pins of the connector.
oh if the red light is flashing either your connection is bad or your sensor took a dump.
yea it was the sensor
thanx evo m |
