Rear Windshield Wiper Doesn't Work
Bought my car second hand. Don't think this was ever mentioned. Is it possible I can go back and ask them to fix it by law or like a good neighbor?
Appears that the motor no longer lets the blade swipe the rain off the back window and it doesn't spray either. Help would be appreciated on how to fix it and what parts are needed. evo 8 mr '05 Thanks |
bump
Did you check the fuse/s
I have a rear wiper assembly that i would sell for 50 shipped if you want it. Motor brackets bolts arm everything, would take you 15 min to swap it all out your self. Just acouple 10mm bolts and one wire plug to plug in.
Not clearly understanding you question is the motor working at and the glass is not coming clean or is the motor completely dead.
If first option is correct then you would need to replace the wiper arm as it is no longer holding enough tension on the glass. If second option then start by checking the fuses as previously suggested. |
| All times are GMT -7. The time now is 05:38 AM. |
