-   Evo Electrical / Audio / Security (https://www.evolutionm.net/forums/evo-electrical-audio-security-180/)
-   -   Car Cranks but doesn't Start (https://www.evolutionm.net/forums/evo-electrical-audio-security/592839-car-cranks-but-doesnt-start.html)
2006IXWW Jan 11, 2012 08:18 AM
I was driving my Evo IX RS and hit a bump with the left front wheel then the car shut off.....pulled over and tried to start it..no luck...
I tried to plug in my OBD scanner to read any CEL's and it says NO Link..I checked all the fuses under the hood and under the dash...all grounds look fine too...
When turn the key to the ON position everything works...radio, lights, dash, ACD switch....
Is this the case of the electrical gremlins?? bad ecu, bad ground... any input would help... thanks
dastallion951 Jan 11, 2012 08:22 AM
well sounds like your getting power obviously because the dash lights all turn on, one could be you mightve blown the fuse/relay on the positive terminal to the battery. If it dont wanna start, try giving it gas while cranking see if it helps. If it does its more of a fuel issue.
2006IXWW Jan 11, 2012 08:45 AM
thanks I will check the fuse on the positive battery terminal...
tried to hit the gas when cranking....still the same.
dastallion951 Jan 11, 2012 09:02 AM
then it could possibly be spark, try pulling each plug wire up one at a time and rest it on valve cover, have one person try crankin it, thatll tell you if each cyl is getting spark.
2006IXWW Jan 11, 2012 07:20 PM
will try on Sat..when I go back to the shop where the car is at....
thanks
infam0usndn2nv Jan 11, 2012 07:29 PM
try checking out the crank sensor
2006IXWW Jan 12, 2012 08:24 AM
going to check the crank sensor again....thanks
80210 Jan 13, 2012 08:58 AM
This happened to me when my 10 Amp fuse under the dash (engine fuse first one top left) was blown, I know you said you checked all fuses though
2006IXWW Jan 17, 2012 09:25 AM
checked all fuses and they're all fine... Crank sensor reads the right voltage...
I think I'm gonna buy a used ECU and see if that fixes the issue..
Thanks for all the replies...
80210 Jan 17, 2012 11:00 AM
One last thought.. hows your fuel pump?
dastallion951 Jan 17, 2012 06:10 PM
^^^thats a good thought , maybe bad pump? or loose connection...took me 2 hrs on my walbro pump install, because pulled it out iirc the connector in the fuel pump housing was only making partial contact. Couldnt hurt to try that, plus its a pretty easy job to fix.
2006IXWW Jan 17, 2012 09:11 PM
I will check the fuel pump again....also I noticed when I cycle the key the "Service Engine Soon" light doesn't come on
I have a used ecu coming so hopefully that works...
CrAnSwIcK Jun 25, 2014 09:36 PM
I just had this problem...turns out the wire from the coil of the MFI relay to the ECU was broken somewhere inside the harness, ran a new wire, and it's good to go. If you jump the switching side of the MFI relay and are able to start the engine, then that's likely the problem...if not, the ECU could be bad...I bought a new ECU myself thinking that was the problem at first.
