Which fuse for add a fuse kit (radar install) radio fuse missing?
Hello! So I'm hardwiring my radar Escort 8500 with their hardware kit. Was going to use an add a fuse kit. It was recommended that I use the radio fuse but when I went to the fuse box I noticed my radio fuse isn't there? Everything works fine so. O biggie but wanted to know which fuse I could use. Thanks!!
Originally Posted by StreakGSX
(Post 10653270)
Personally I wouldnt bother with an add a fuse. I would use the switched 12v from your radio and tap into that. The wire is red. Then bolt your ground right behind the radio on the dash bar where some other grounds are bolted and you should be good to go. |
I don't know but in searching threads a lot of people don't have a fuse there. I already installed I just used the add a fuse with he use for the cigarette lighter.
Thanks for the reply! |
(Post 10654801)
Thanks for the reply! you can use the secondary radio fuse under the dash too |
Originally Posted by ikt
(Post 10655058)
mine didn't either, might be some sort of optional thing.
lol, that wasn't where I asked the post to go
