-   Evo Electrical / Audio / Security (https://www.evolutionm.net/forums/evo-electrical-audio-security-180/)
-   -   Evo V won't start after timing belt and CPS change (https://www.evolutionm.net/forums/evo-electrical-audio-security/702839-evo-v-wont-start-after-timing-belt-cps-change.html)
Yazer Nov 6, 2014 08:35 AM
So my evo died during driving. Found out my balancer belt was cut and destroyed the crankshaft position sensor. I changed the timing belt at the same time but now my car doesn't start. My battery was gone empty because car stood in garage for a month waiting for a motivation to fix it.
Yesterday i tried to start the car after belt, CPS change and loading battery, but it doesn't start. Keeps cranking, gets spark and fuel but nothing happens. There is no generator belt installed atm though so might it prevent starting?.
I didn't get spark at all before changing crankshaft position sensor, now there comes spark after installing a new one.
Ev0ikon Nov 6, 2014 02:15 PM
No Alternator belt?
Yazer Nov 6, 2014 07:26 PM
Nope. Wanted to give a test start before installing it.
Ev0ikon Nov 7, 2014 12:46 PM
Ok. I would check sensors (Crank and Cams), then timing again and make sure cams are timed correctly. If they are all good I would do a leak-down test. Hope the timing belt didn't jump.
alpinaturbo Nov 7, 2014 08:34 PM
You may have missed to plug in something, like coils, or injectors, or TDC/Cam Sensor.
There is no problem, its a simple omission
I am sure its electrical-sensor related...
Let us know.
If you don't find it, I'll connect you to your fellow countryman who can speak to you to help you out.
Yazer Nov 7, 2014 11:17 PM
Checked all wirings, there was one engine grounding loosened, but tightening didn't help.
Could my ignition be 180 degrees off, because it's backfiring occassionally to my valve cover breathing pipe when trying to start? Wondering how it is possible though because i've checked timing marks many times. I'll try today with a new camshaft position sensor and hope for the best.
todd6027 Nov 8, 2014 03:01 AM
check coils/leads/connectors are on the right cyls ,simple one i know but it has been done
Yazer Nov 8, 2014 03:13 AM
Ok i double checked my valves, lifters and all.. Found out my intake valves are broken. Lifter/cam backslash is about 4mm (valves doesn't come whole way up). I could take lifters away with my fingers.. Didn't notice it before because there was so much oil on lifters. There was few lifters stuck between cam and valve so it felt like everything is ok when I rotated the engine by hand. Looks like my timing had jumped a whole way around from crankshaft, that's why it looked like timing had jumped only 1 tooth when I checked everything before changing timing belt. :crap:
Ev0ikon Nov 10, 2014 01:12 PM
Sorry man. It's what I suspected too. It's so easy to ding/bend the valves on these engines just a tooth or 2 off.
