evo 9 cluster wiring diagram
hey guys doesnt anyone have a diagram or a link to an evo 9 dash gauge cluster wiring diagram which shows what each pinout is.
thanks heaps, it doesnt tell me what each pinout is for the cluster through. just shows which plugs are used. c-106 c-107 c-108
What exactly do you wana know? I can check all data tomorrow. They have all schematics.
thanks i need to know which pinout is the power, earth and pulse on the speedo cluster. sorry i have no idea about wiring, i was told to find it for my wiring guy
Speedo or rpm?
thanks heaps for your help. what i really need is to know which pin coming out of the speedo cluster is for the speed pulse, power, and earth. so if looking at the back of the cluster with it out of the car i need to know which pinout is which. i have one speedo i need the k's to go back to zero for a complete new race car build and the other needs ks put onto it to replace a damged cluster.
I checked alldata and its the same diagram i provided
thanks but im sorry i cant see it.
if you were going to take the cluster only into a workshop, what pinouts on the cluster is the speed pluse, power and earth. |
how did you solve the issue? I need the some help with both the speedo and the rpm
2 Attachment(s)
Yer found them on another post, the wires charge colours on different models but are in the same places. 11 on the white plug is rpm and 12 on the white plug is speed
Where did your run the wires to? i connected it to the gear box speed sensor and i didnt get a signal.
na i just needed the pin outs so i could get a company to change my ks on my 260k speedo to be the same as the factory speedo
