Help please swap evo 7 ecu into evo 4
Hi im new in this forum..
I swap evo 7 ecu into evo 4 and i changes all pines needed.. Swap cable 8 to 22 Disconect 87 20 to 32 21 to 34 6 to 53 Disconnect 91 And dont start...dont work the fuel pump.. 😕 Ecu rip ?? Pls help |
swap pins 8 and 22 back to original and try it again.
I had the exact same issue. |
Originally Posted by meka
(Post 11850029)
[QUOTE = meka; 11850029] vuelva a cambiar los pines 8 y 22 al original y vuelva a intentarlo.
Tuve exactamente el mismo problema. [/ QUOTE] That are the problem, i change 22tm to 8 and start ... Thanks bro ✌️✌️✌️😎 |
