evo fuel pump harness replacement
good day,
I am in the process of installing a walbro 450 fuel pump in my evo 5. Unfortunately when i pulled the old fuel pump out, it was evident that the old owner hasnt done that great of a job on the old one. The Fuel pump harness that connects the fuel pump to the hanger assembly is not useable. I have found that STMTUNED sell a harness for an evo 7-9 but nothing for the 4-6. Does anybody know if the harnesses work in the 4-6? or are the plugs completely different? https://stmtuned.com/products/fuel-p...-oem-evo-7-8-9 The link above is for the replacement harness in question. kind regards Muhammad Vadia |
Hello / Welcome @vadia
I certainly do not know, but i will tag one of our better fuel pump members @2006EvoIXer The guys on the MLR forum would likely know. That forum has many more of the older model EvO owners there Joe :) |
I have no idea about evo 5. Do you have a picture of your harness? We just need to look at the connectors to compare. If different, then you have to search for the correct connector and switch on that STM unit. Spoolin Up has been amazing at finding weird connectors, so they would be a great source.
Originally Posted by vadia
(Post 11876069)
good day,
Well said there Don. Great advice
We dont necessarily need the EvO5 pump details, just take a look at plug and compare If the connectors are the same, good chance the connection priority's will be the same? |
