Subs
I'm looking to replace my stock 10" with a 12". Will a 4ohm 12" be compatable with the stock system?
Hey Adam @Adam Matlock
Welcome aboard the boards Placed your first post here where you can get some advice Hey, ive got an RS EvO & have no radio. Kinda miss it as im a music lover |
Did a little searching & found these. It may provide some ideas @Adam Matlock
https://www.evolutionm.net/forums/ev...enclosure.html https://www.evolutionm.net/forums/ev...han-stock.html |
Seems like there's a few options that fit the depth of the enclosure.
https://www.evolutionm.net/forums/ev...-location.html I can't remember what stock impedence is for factory sub, but just use a multimeter to measure it and then make sure the new sub matches it unless you're planning to run a sub amp. As far as I'm aware most of the ones listed in the thread above will work. |
