AnyOne with KOYO radiator?
Have you noticed any major differences? Did you get a new Rad cap?
Ive got one coming and was also wondering what coolant you used for it. I am guessing the same stuff that Mitsu recommends. Did you change out the Thermostat or keep the original one? What about pipes too?
Thanks
AUS
Thanks
AUS
just got mine in , kept that stock theromsat but every thing else seems to be fine , i caint tell any huge impovment ,but its the mental thing nowing that you have a alumiunm RAD . I used the stock cap and flushed my cooiling and used prestone coolant .
Got it in my car!
Weight its more like 3-4lbs
Im using the Stock 1.1 radiator cap and its about a 5-15 degree cooler than stock!
But then i replace the radiator w/ Samco Hoses, and Ralliart Theromostat.
guys...how much room do you have between the back of the Radiator and the turbo heat shroud. I put mine in tonite and it was a real tight fit. Im a bit worried that it is too close.
555R
31
Nov 22, 2007 12:28 PM
