Stock BOV that bad?
Old Sep 29, 2004 | 11:44 AM
mfoerschler's Avatar
Stock BOV that bad?
OK, I've read a lot of anecdotal evidence on here that suggests that
a) the stock BOV leaks
b) the hoses are loose causing a leak
c) it's plastic so it must be bad
d) all of the above
What's the real story with the stock Evo VIII BOV? Is it really THAT bad?
Old Sep 29, 2004 | 12:34 PM
SinCityEvo's Avatar
Mine holds 20 psi fine. I just tightened all the clamps which were very loose. All the IC pipe clamps were loose also. Holds solid now. I didn't want to deal with adjustment issues that aftermarket BOVs have and don't care about the sound either.
Old Sep 29, 2004 | 12:56 PM
marksae's Avatar
d) all of the above
There was some guy on here who did some pressure tests and proved *his* stock BOV leaked. Try doing a search. It's on here somewhere.
I would attribute the leak due to the BOV's construction. Perhaps plastic BOVs are constructed w/ looser tolerances and surface flatnesses, therefore don't seal as well.
Old Sep 29, 2004 | 12:58 PM
EVOKing8's Avatar
the guys at mitsu even said it was crap...its a peaice of plastic on another piece...guess thats what they give when money is tight
Old Sep 29, 2004 | 02:09 PM
sleet's Avatar
Mine holds 20psi just fine.
Old Sep 29, 2004 | 02:16 PM
jj_008's Avatar
I have ran mine up to 27psi. It also holds 23 psi like a champ.
Old Sep 29, 2004 | 02:42 PM
sleet's Avatar
Not on the stock turbo I hope...
Old Sep 29, 2004 | 05:47 PM
SurfguruJon311's Avatar
Old Sep 29, 2004 | 05:50 PM
Keyser Soze's Avatar
The dealership just installed another one ony my car b/c the first one leaked....... ill keep getting it replaced until i decide to buy a new one
Old Sep 29, 2004 | 06:14 PM
vletnguyen's Avatar
mine leaks. replaced it with turboxs rfl..now i am annoyed at the sound
Old Sep 29, 2004 | 07:18 PM
SinCityEvo's Avatar
Was that under warantee? What does a dealer charge for an OEM one?
Old Sep 29, 2004 | 07:21 PM
100% covered under warranty ... the part is about 113 i belive and labor is 39 bucks ... ill be upgrading to an aftermarket BOV if this one fails as well
Old Sep 29, 2004 | 07:39 PM
jj_008's Avatar
Stock turbo. Race gas.
audiofan
Sep 9, 2016 09:11 PM
Pawl7
Mar 2, 2014 09:53 AM
brakeboost980
Apr 5, 2012 12:21 AM
brakeboost980
Feb 26, 2012 09:48 PM
MYFIRSTEVO
Aug 5, 2005 10:54 AM
