Engine gone need parts
My motor leaned out this morning and melted #3,4 plugs, and possible #3 piston.
I haven't pulled the head yet.
https://www.evolutionm.net/forums/sh...d.php?t=107565
I still need to find out why it leaned out. I'm leaning toward a bad fuel pump, or problems with my UTEC injector drivers-VRS-PTE 680cc injectors.
The one thing I know I'll need is new pistons/rings, maybe oversize, bearings and gaskets. Hopefully the head is ok, but may need parts too.
I may have to do a complete rebuild.
I don't have crazy money for some JDM stroker kit. I'd like to know the best place to buy quality engine parts from a knowledgable staff.
Recomendations?
Recomendations?
Well, if you end up needing stock pistons, rods, and crank, I should have a set since I have a spare short block that I'm going to be using for the stroker setup.
AMS(?) Has some eagle stroker setup available, also call buschur, he has something that will be available shortly if you want to do a stroker setup...
Got damn, I hate that it happened to you! Jack has the good advise though... it would probably be the least expensive to take the AMS/Buschur stroker parts to your engine builder. Pending what you find, will tell about the head.
