po 234 fuel cut problems
Old Nov 8, 2004 | 06:01 PM
SOUTHSIDEITALIA's Avatar
I pulled the code:
DTC P0234: Turbocharger Wastegate System Malfunction
I recently installed a walbro 255 and 264/264's.
Any ideas for S-afc settings or alterations to buschurs stage 2?
Possibly some colder plugs for starters?
MODs are:
MAF induction pipe INJEN kit w/ upper I.C. piping & Forge D.V.
Boost set to ~20 w/Halman pro rx
Full 3" Turboback
Old Nov 8, 2004 | 06:04 PM
DynoFlash's Avatar
I have a stage rev flash that will eliminate this condition for $79.99
And our through the mail flash will also fix it for $200 and you get a tune at the same time
Old Nov 8, 2004 | 06:16 PM
what is a staged rev flash? I would not to completely eliminate the of the stock ECU's safety features unless I absolutely have to. I believe it is saving my butt right now. Three feul cuts at WOT in the past two days. Weather is in the mid to high 50's however.
I would like to street tune, using a wideband. What are the benefits/disadvantages versus the flash
