Oil Leak
Old Nov 10, 2004 | 04:08 PM
Mach 8's Avatar
Unhappy Oil Leak
I have a small oil leak around the drain plug. i checked it and its tight. has this happended to anyone else. what did you do
Old Nov 10, 2004 | 04:10 PM
NYEVO8's Avatar
did you change the ring at your last oil change. i am pretty sure you have to change the washer on the plug every oil change or it will leak, very little though
Old Nov 10, 2004 | 04:17 PM
90GSX-03EVO's Avatar
Yeah, you have to put a new crush washer on at every oil change. This sounds exactly like what the problem is.
It's part number MD050317 and they are about $1.00 each from the dealership.
Old Nov 10, 2004 | 04:18 PM
Mach 8's Avatar
no i didnt change it. so yall think thats it
Old Nov 10, 2004 | 04:19 PM
Mach 8's Avatar
can you get them from an autozone or advanced auto, ect , ect
Old Nov 10, 2004 | 04:22 PM
kdogg's Avatar
If you buy factory oil fiters from the dealer, they usually give you a washer too. Just in case, did you check to see if you threaded the plug properly?
Old Nov 10, 2004 | 04:24 PM
I'm sure you might be able to. I just bought 10 of them from the local dealership so that I didn't have to go back and forth there every time I need to change my oil.
Old Nov 10, 2004 | 04:39 PM
Mach 8's Avatar
ok
