tranny whine yay. Help please!
Old Nov 22, 2004 | 08:06 AM
wingnut's Avatar
Whine in first and second here. Gears probably have a more straight than helical cut to them.
Old Nov 22, 2004 | 08:14 AM
SuperHatch's Avatar
All the gears are cut at the same helical angle. The problem is that the first and second gears interface more than the higher gears due to a larger gear and greater gear reduction. Since more of the gears interface there is more tooth contact and hence more noise produced. If you have having noise in first and second you may have a problem with the 1-2 hub/sleeve since first and second share the same one.
The problem here is that everyone describes the noise as a whine, but every whine is different and different whines could mean different things making a problem like this very difficult to diagnose over the interwebs.
- Steve
Old Nov 22, 2004 | 10:31 AM
vicbdn's Avatar
Yes the intarweb is not a good place to solve a complicated problem. I'm going to give TRE a call after I get back from errands Thier pricing seems nice!
Old Nov 22, 2004 | 11:50 AM
SuperHatch's Avatar
Old Nov 22, 2004 | 12:37 PM
titaniumkingpin's Avatar
my whine was caused by a bad throw out bearing. mitsu is taking care of it for me right now.
Old Nov 22, 2004 | 03:28 PM
plokivos's Avatar
Originally Posted by SuperHatch
I just had my tranny and T-Case rebuilt by Jon at TRE. I spoke to him at length on the phone about the problems people are having with their Evo drivetrains and the things that he has come into his shop. He told me that every Evo transmission that he's rebuild (except mine ) has had a cracked first gear. Not cracked like you might think but subsurface fractures found by magnafluxing the gears that were most likely caused by abusive launches. He said these cracks will cause gear noise even though the gear works fine. Of course continued abuse will cause these fractures to become full on broken gears at some point. He also said he sees a lot of damaged hub/sleeve assemblies which also result in drivetrain noise. I can go on and on, but if you want a real healthy diagnosis of your problem give Jon at TRE a call and talk to him for a while. (www.teamrip.com)
BTW, I didn't have by drivetrain rebuilt because of any noise, I had it done due to the many TSB's out on the tranny and to make sure everything was in good order before the coming race season.
- Steve
how much was the rebuild? What he do, stronger bolts, sub-structure support? Supporting pin for gear stabilizing?
what is it man! lol.
Old Dec 17, 2004 | 08:52 PM
Blitzbaster02's Avatar
My car is doing this tonight! I went to the track and made some launches, my car then proceeded to wheel hop. The whine is only during deceleration, not when accelerating. Its much louder than the normal whine.
