A/C hose removal
Old Nov 22, 2004 | 09:37 PM
stvbreal's Avatar
A/C hose removal
I was wondering if anyone has done this or if there is a way to do this. I want to remove the A/C hose. It's the hose on the bottom of this photo by the engine damper, but you guys know that. Anyone try this? I never use the A/C and just want to get it out of there. Later on down the road I will remove the A/C completely and go with a shorter belt.
Old Nov 23, 2004 | 11:48 AM
Jamie@WORKS's Avatar
Steve,
You'll want to have all the gases removed from the system first. After that, it's only a few bolts that need removed to get the line out of the way. At that point you can dig out a few other parts including the A/C radiator.
Old Nov 23, 2004 | 11:59 AM
stvbreal's Avatar
Excellent. I should have posted this on CDSM instead. Thanks for the reply Jamie.
Old Nov 23, 2004 | 12:02 PM
superz's Avatar
Make sure you evacuate the system first, you can get a shop to do that for you. Please dont just crack the lines and let the freon escape, you can get poisoned that way. After that everything is cake.
Gil-superz
Old Nov 23, 2004 | 01:06 PM
stvbreal's Avatar
I would never do that. That's some bad stuff in there. Any idea the cost of draining at a shop? Shouldn't be much. Just the cost of disposal I would think.
Old Nov 23, 2004 | 07:44 PM
superz's Avatar
They never dispose of it, it is recycled since there is no loss of quality with newer freon. I would estimate the cost would be under $50 since they do get to keep a couple of lbs of R-134 which I assure you they will install in some other vehicle for a profit.
Gil-superz
Old Nov 23, 2004 | 08:00 PM
chinto's Avatar
how much weight would you save by takeing the ac off? what other advantages are their to doing this?
