Mitsu boost gauge vaccum reading at idle
When the engine is idle, what is the correct vaccum reading on the oem mitsu gauge for the boost??? my is at like 25 is that normal? I saw a pic of another guys gauge his vaccumm reading was like 35 or 40 much higher than my
what is the normal reading for a stock MR?
Mitsu gauge is in kg/cm^3 for boost and cm/hg for vacuum. Use www.onlineconversion.com pressure section to convert to bar or psi boost/vac gauges
Originally Posted by Jorge T
on the stock Mitsu gauge I see 48-50
Do you guys think I got a broken boost gauge?
My is NO where near the 6oclock position more like....8 o clcok does anyone know what this might mean? if my vaccum and boost reading is wrong? beside the vaccum tube bein kinked b/c I checked it dont seem to be kinked to me
Originally Posted by EFIxMR
mine reads straight down in the 6 o'clock position. forgot what the correlates to tho.
there is no such thing as negative psi. at idling speed an engine at sea level should show a steady vacuum reading between 17" and 21" HG. A quick opening and closing of the throttle should cause vacuum to drop below 5" then rebound to 21" or more.
1 in HG = 2.54 cm HG
hello i have autometer gauge i read 20 21 on vacumm at idle and when im shifting gears it goes to 25 or 26 ?? does that mean i have a leak or something when im at at idle i hit the gas and let go the vacumm goes all the way to 25 then slowly goes to 20 21 again thanks??? is that normal thanks
