Oil Catch Can?
The PCV system is a nifty anti-pollution device that uses intake vacuum to suck crankcase vapors back into the intake. These crankcase vapors condense in the intake system and leave an oily residue in critical areas such as the IC and intake runners. An oil catch can simply catches the oily residue and allows the vacuum to pass. This greatly reduces the buildup of oily sludge in the intake system.
The combustion of any hydrocarbon fuel will leave some carbon deposit regardless, although I'd be quick to point a finger at the PCV system to be an aggravating factor, simply because burning high mw hydrocarbons (oil) leaves far more residue than burning gasoline.
Are EVOs equipped with EGR? I don't conscioiusly recall seeing it.
I've never looked at an EVO head, but I would imagine a DSM head is similar.
If you take the exhaust manifold off, there's an opening in #4 cylinder's (the one to the far right) exhaust port that goes back to the intake side of the head and into the intake manifold and then the EGR valve. Our intake manifolds have an extra channel next to the first runner for the EGR.
