MR downpipes and BOV's.....
Old Dec 9, 2004 | 08:30 AM
David Buschur's Avatar
Hello guys,
We got an MR in here yesterday and now we have the downpipes for them done. They are ready to ship, full 3" just like our others and the price is still only $275.
Also, the MR does not use a steel BOV like I see many guys talking about. It uses the same old plastic valve as all the rest.
Thanks for reading.
David Buschur
www.buschurracing.com
Old Dec 9, 2004 | 08:33 AM
Rez90's Avatar
are the MR downpipe's going to be the same for all the 05's? or can you use a downpipe from an 03/04 to fit a regular 05?
Old Dec 9, 2004 | 09:11 AM
JustDSM's Avatar
Just to add on to what Dave said, only the JDM MR BOV's are metal. All USDM EVO's have the same valve... The plastic one.
Old Dec 9, 2004 | 11:32 AM
The JDM exhausts will probably fit all the years as I guess they all had the active center differential.
As for ours it is going to be a hit and miss. If you have one of our old systems there is a very slim chance you might be able to get it on your MR. The difference is slight but it is enough that we had to change how we cut/welded and put it in the weld fixture.
David Buschur
Old Dec 12, 2004 | 10:31 PM
Evo Police's Avatar
With this new exhaust will we still be able to retain the stock lower tie bars on the Evo MR?
Thanks...
Old Dec 13, 2004 | 12:39 AM
mrbkkt1's Avatar
i'm asuming, everything will fit 05 gsr?
Old Dec 13, 2004 | 05:55 AM
This downpipe does retain the lower tie bars. Should also fit the gsr.
David Buschur
Old Feb 2, 2005 | 07:47 PM
thatsMR2u's Avatar
any dyno runs after install?
Old Feb 2, 2005 | 10:14 PM
No dyno runs on an MR if that is what you are asking, we have been doing a ton of work on the RS on the dyno though.
David Buschur
David Buschur
Jan 18, 2006 06:58 AM
David Buschur
Sep 6, 2005 01:38 PM
David Buschur
30
Feb 15, 2005 04:08 PM
David Buschur
61
Jul 31, 2004 07:41 AM
David Buschur
May 3, 2004 08:01 AM
