stock exhuast cat replacement
Old Dec 12, 2004 | 08:56 PM
WishIhadaEvo's Avatar
is there any test pipes out there that u can use to put on a stock exhuast to free up some ponies for awhile til i can get a full turbo back? if so can yall post some links thanks.
ryan
Old Dec 12, 2004 | 08:58 PM
GreedMOTO's Avatar
Helix cat-delete, supposedly a direct fit.
http://www.gruppe-s.com/Evo/evoex.htm
Perrin cat-delete
http://www.lancershop.com/customer/home.php?cat=9
Old Dec 12, 2004 | 09:03 PM
ok thanks man .. anyone got one? what hp u think it will give off?
Old Dec 12, 2004 | 09:08 PM
GreedMOTO's Avatar
Cat delete pipes have a tendance to throw a Check Engine Light (cel)
This is due to an abnormal reading from the Oxygen sensor (o2) mounted inside the cat or test pipe. The cel fix is just that, a fix. You have to access the wiring harness for the o2 sensor under the passenger seat and hardwire the cel fix to the harness. This overrides the signal from the o2 sensor to the ecu, keeping you from getting a cel.
Old Dec 12, 2004 | 09:40 PM
MaxR's Avatar
i have a helix de-cat pipe on the stock exhaust. with spark plug anti foulers plugged in to the manual cel eliminator on the test pipe i have not had one cel. i think it adds about 15 hp even on the stock exhaust. sounds stock too.
Old Dec 13, 2004 | 09:33 PM
ok yaeh i found out what the fix is. whats this anit fouler.. i was reading a diff thread and some people wehre saying whatever those are that they dont work.
Old Dec 13, 2004 | 09:41 PM
lil'evil_evo's Avatar
The UR test pipe is the best one. No cel ever and it's only $90 shipped.
Old Dec 14, 2004 | 02:19 AM
Derek888's Avatar
Is the UR test pipe 3inch?
Got 2 questions.
What exactly is a high flow cat compared to a test pipe. Wouldnt any stainless steel 3inch test pipe work just as good as other brands because its just a pipe with no bend and a hole in it
Old Dec 15, 2004 | 09:18 PM
any link to this UR test pipe?
Old Dec 15, 2004 | 09:22 PM
Nad1370's Avatar
www.ultimate-racing.com
Old Dec 15, 2004 | 10:06 PM
Jakeg97's Avatar
Got 2 questions.
i think that any 3 inch test pipe would work just the same. i also think a high flow cat has less or larger size bends than the stock cat
