Motec M800 VS AEM Plug and Play
Originally Posted by Crufty Dusty
Right, just like 40 x 21 maps, according to you, street guys have no use for it.
I guess street guys also don't need to have that many I/O either. At least on the MoTeC, if you do run out of I/O, there are expansion options.
I guess street guys also don't need to have that many I/O either. At least on the MoTeC, if you do run out of I/O, there are expansion options.As for the I/O goes, some will not use half of what is available, but the really serious guys will use all of the input sensors, and a good chunk of the outputs, if they start to get creative. At least it is there if they need it.
Knock control is available on MoTeC, just that it makes you jump through some hoops to get there.
There's no doubt that AEM offers great value, don't think anyone's disputing that.
Originally Posted by Jason Siebels
No..... they don't! There is no setup tables in MoTec's software for knock control whatsoever. You get knock control on a MoTec by purchasing a J&S knock sensor, but this doesn't give you the ability to tailor your knock curves for each engine like the AEM.
Knock is always after the fact, and it isn't good for the engine, with knock control or without. If you're saying that the car is always going to be running on crappy octane then yes I would agree with you that is a useful feature in the sense that fuel delivery and timing can be retarded until you get better gasoline. AEM has knock restore which is nice, but as mentioned earlier, if the engine is consistently knocking, your problems lie elsewhere, outside of the EMS.
Jason.
Well there within lies the problem. Street cars run pump gas, and with pump gas you can't guarantee the quality of the gas. It's obviously a useful feature or manufacturers wouldn't spend so much money using them on street cars.
Jason.
Jason.
What I was trying to put across, which I suspect you completely missed, is that knock control is not meant to define the limits of the state of an engine tune, because knock control by its very definition (actually an oxymoron), is after the fact. Knock control is not going to save the engine if it keeps detting.
I doubt the manufacturer is going to warrant the engine if it was meant to run on 93 octane and the owner consistently uses a lower octane gasoline.
I didn't miss anything...you are right, knock control is a reactive feedback. The manufacturer has to warranty the car NO matter what octane you put in it. For one, they can't guarantee that any gas is of it's rated octane, two, they have no way of testing it. Do you think you could get 70AWHP with an EVO by putting a computer on it and re-tuning it if the manufacturer wasn't considering crappy fuel in their calibration? Of course they do, that is the whole point. They can recommend minimums, but they still have to cover warranty no matter what fuel you put in the car. Knock control is a safety thing, and the systems today can use it to determine the octane of the fuel you have and adjust the timing maps accordingly. Bottom line.....rather have it, than not!
Jason.
Originally Posted by EFIxMR
on an AEM what a/f can you run with an idle of 1000 rpm on 1000 cc injectors?
Jason.
I love the MotecM800! I am currently using it on my 2004 EVO using the stock wiring harness. I am controlling my anti-lag with my intercooler water spray switch. Also, I have the Motec Mini Dash Display to see my parameters without using a laptop. And I am using the CAN interface to comunicate with my ABS computer to track individual wheel speeds and braking force, and G-force.
It's a awesome ECU, but if you can't afford it, the AEM will do just fine. I have tried them both. I prefer the Motec M800.
Here is the guy i use for mapping my M800. There some more info on there for the motec
http://www.dentistmapped.com/
motec better than aem, more features, suspension setup/monitoring.
sounds better too. Mo Tec. A ee mmm...
lol
if not suspension monitoring or tuning, aem is a cheaper yet hella good tuning choice, i think.
lol
FS[MidWest]: Motec M800 PnP for Evo 9
Mitchubishievo
17
Nov 28, 2017 03:13 AM
fatbastard
Mar 17, 2012 07:59 AM
