twin turbo evo?!?
Old Jan 17, 2005 | 08:18 PM
silviadrifter's Avatar
Question twin turbo evo?!?
a friend of mine says he's gonna sell his se-r and buy an eclipse and a twin turbo evo engine. so far i haven't seen or heard of an evo with twin turbo but i dont kno almost anything bout mitsubishi's. some plz tell me if this is posible.
Old Jan 17, 2005 | 08:20 PM
ezhangin's Avatar
not gonna work very well, think about it...
where is a 4 cylinder gonna get enough exhaust to power two turbos?
Old Jan 17, 2005 | 08:21 PM
evo_dadi's Avatar
he probably misunderstood the twin scroll design of the turbo into a twin turbo evo
Old Jan 17, 2005 | 10:04 PM
Karash's Avatar
well I will be blunt and say your friend is ignorant.
twin scroll yes, twin turbo no...and why would you anyhow.
Old Jan 17, 2005 | 10:06 PM
DaGuL's Avatar
Anything is possible... JDM Impreza wagon GT is a 2.5 twin turbo flat four... The idea behind twin turbo is usually to lessen lag...
Old Jan 17, 2005 | 10:08 PM
KillaSweep's Avatar
Talk is Cheap...Turbos aren't
evo81's Avatar
........... twinturbo,c'mon man
Old Jan 17, 2005 | 10:22 PM
DaGuL's Avatar
Well, on a side note, no one thought that twin charging an MR2 was possible and it was done... 2nd gen MR2 are twin turbo as well... There's the JDM 4 banger supra that's also twin turbo... Someday, someone with enough financial backing and R&D will put one together just for shiz and giggles...
Old Jan 17, 2005 | 10:30 PM
EidolaDream's Avatar
yes that has happend alot.. I have had to explain to several people about that... Also one guy was so certian the oz rally lancer has one turbo and the evo has twin lol
Old Jan 17, 2005 | 10:47 PM
negativeB's Avatar
i thought the way twin turbos worked was that there are two different sized turbos. a smaller one that is used first and then disengaged when high rpms are hit. then the larger one takes over. i maybe wrong, but if i'm right, then it wouldn't be a problem at all would it?
Old Jan 17, 2005 | 10:48 PM
DaGuL's Avatar
That's pretty interesting how many people are uninformed or misinformed nowindays... More times than others, people are just lazy to search for the information they're inquiring about...
Old Jan 17, 2005 | 10:55 PM
DaGuL's Avatar
Yes, most setups are like that and are refered to as sequential turbo setup... There are also setups where two same sized turbos are used non sequentially where one feeds into the other then to the intake tract... There's also another setup common on bigger engines where two turbos of the same size are used and both feed into the intake tract... Take the twin turbo Z for example. I don't know how true this holds but it's supposedly referred to as the double breasted motor. Almost two of everything... Two turbos, two throttle bodies, etc, etc...
In relation to the EVO, a twin turbo setup is possible in a sequential setup. It's possible to make room for it... The biggest obstacles are cost, space, engine management, and turbo sizing...
Old Jan 18, 2005 | 06:52 AM
ebbeast2005's Avatar
yea on ebay alot put it as "twin turbo" when its sposta be "twin scroll turbo"
Old Jan 18, 2005 | 06:57 AM
bahamut's Avatar
I do believe most TT setups are sequential . . . then again, supra guys strip their TT to single for bigger linear power. Basically, simplify things.
Old Jan 18, 2005 | 07:03 AM
badlooser's Avatar
yes anything is possible but is it worth it?
