torn between HKS EVC V & Blitz SBC-ID3
Old Jan 20, 2005 | 03:44 AM
Derek888's Avatar
I really like both but still trying to get more opinions on the Blitz SBC-ID3. I heard HKS EVC V works really well but its complicated to use.
Old Jan 20, 2005 | 03:55 AM
Curt@MrLed's Avatar
Former Vendor
hks
Old Jan 20, 2005 | 03:58 AM
Derek888's Avatar
2 more questions.
On the HKS EVC V what are those 2 big volume knobs for? It does take up more space when installing the HKS unit.
Stock psi is 19.5??? How much higher boost(max 21 psi?) can I turn it up and will I feel a difference in speed? I want to know what 1 psi in boost increase feels like.
Old Jan 20, 2005 | 05:05 AM
PPI's Avatar
PPI
/\ have you got rid of your fuel cut yet? If not that will limit you as well.
My vote for blitz, I really like mine on my wrx...
Old Jan 20, 2005 | 05:29 AM
Derek888's Avatar
Are you saying that I need a better fuel pump in order to turn up the boost?
Old Jan 20, 2005 | 07:11 AM
gunzo's Avatar
blitz .. simple to use .. and has other options once you fit the RVIT or the powermeter ID3..
I got it up and running with 45 mins and figured out how to set the boost like within 10 mins .. all using manual setup of course ..
Old Jan 20, 2005 | 08:04 AM
Homegrown_Evo's Avatar
No, I think he is saying that once you turn the boost up, if you turn it up too high then your fuel will cut. I am not sure what fuel cut is on these cars..but it sucks when you hit it. I hit it once when mine spiked to 24lbs on the greddy profec B. I switched to a hallman mbc that works great. Just my 2c...
Turning the boost up 1 lb. won't really feel that different...the boost controller just holds the boost till redline, when the stock spikes to 19.5 for a second and drops to 16. It will feel stronger all the way through to redline...
Good luck on your choice
Old Jan 20, 2005 | 08:18 AM
SJ EVO 8's Avatar
my votes for the hks also.I have no problem at all with mine.
Old Jan 20, 2005 | 11:12 AM
TeenEVOwner's Avatar
I would go with the HKS...I installed it myself and I have been very satified with it...It has a warning system on it so you get to set where your warning level boost is at...mine is set at 22psi..so if my psi will spike at any given time (lets say the temperture dropped 20 degrees) then once it hits 22 then it will essentially kick the boost controller off and run on the wastegate...which will limit the psi to around 9psi...It has other settings as well, but I have not looked into them yet
My advice is go for the HKS
Old Jan 20, 2005 | 11:23 AM
en1gma19's Avatar
If you HAVE to have one of those two I say go for HKS. I used to have it and it held rock solid boost and I thought it was very easy to use.
However, if you are open to suggestions I would say go for a MBC, like a Hallman. You can get one for less than 1/5 of what you would spend on the HKS and it will work just as well. Save your money for more important things.
Old Jan 20, 2005 | 02:25 PM
EVO8LTW's Avatar
Happy with my Blitz sbcid3 and powermeter combo. They are very entertaining to play with. I wouldn't cough up the money for them if I didn't have a boost controller, but they were already on a used 03 Evo that I bought and I just transferred them to my RS. Blitz also has the warning feature and is very easy to adjust.
Old Jan 20, 2005 | 07:38 PM
Derek888's Avatar
thanks for the info guys... on the HKS EVC V, whats the other controller for the one with the 2 volume buttons?
Old Jan 20, 2005 | 07:43 PM
DrBump471's Avatar
Blitz SBC i-d works fantastic. This is a personally preference thing here. You will be hard pressed to find someone that has used both. At around 500 bucks a pop I wouldn't be purchasing 2 just to find the difference. Both are going to have relatively the same features but I prefer the Blitz cause thats what I bought.
Good luck on your decision.
Old Jan 20, 2005 | 07:52 PM
Spec C's Avatar
I vote blitz also.. I used it on my 400whp wrx with great sucess, and have one on my evo with RNR turbo kit.. Very easy to use, and holds boost well..
Old Jan 20, 2005 | 08:00 PM
SidewaysEvo's Avatar
i have the hks, and i have no problems with it. pretty easy to use too.
