What cams should i get?
Old Feb 13, 2005 | 03:56 PM
Evo348's Avatar
Im decing on whether to get the 264s or 272s ( with cam gears) but i dont plan on upgrading the turbo anytime soon so supossely the 264s are the best ones to go, yet the 272s will give me more power and with the cam gears i should be able to fix the crappy idle. I have an AMS 3" TBE, hallman mbc @ 20psi, buschur air filter. So what should i do people? Also do i need to reflash the ecu if i own a s afc II?? and is it necessary to tune my car right now with the few mods i have or not yet?
Old Feb 13, 2005 | 07:00 PM
sleet's Avatar
Ok, I think if you're going to be adding cams and whatnot you should get a Walbro fuel pump just as insurance. I say if you're not going to be upgrading the turbo for awhile, just go with the 264s or try a combo like 264/272. You will be able to tune it with the SAFC, just depends how skilled you are with it. But after cams and all that, yes you should get it tuned properly.
Old Feb 13, 2005 | 07:16 PM
evo81's Avatar
a search will help you in your quest for knowledge about the cams you seek
