did u disconnect the battery to install your TBE?
Old Feb 15, 2005 | 09:03 PM
Evo348's Avatar
would this make any difference in allowing the ecu to re learn the bigger exhaust flow? is this necessary? let me know thanks
Old Feb 16, 2005 | 09:48 AM
Evo348's Avatar
cmon people its a yes or no question
Old Feb 16, 2005 | 09:49 AM
BSREVOLUTION's Avatar
just do, wouldnt hurt.
Old Feb 16, 2005 | 10:49 AM
PHiSH's Avatar
I did. I disconnect the battery whenever I install something that involves the electrical system in one way or another (O2 sensor). It can't hurt anything but losing your radio stations
Old Feb 16, 2005 | 10:55 AM
its_hey_ma's Avatar
you guys got radio's in your car?
Old Feb 16, 2005 | 10:59 AM
PHiSH's Avatar
It drowneds out the squeaks and rattles. It's the only reason I have one in the Jetta too.
Old Feb 16, 2005 | 11:12 AM
sneakychaos's Avatar
amen to that...
Old Feb 16, 2005 | 11:32 AM
05-EVO-GSR's Avatar
Just do it. Whether or not it works is remained to be seen. Depending on which system you are installing, get ready for a louder exhaust note. Be sure your radio is up to par to help drown out the noise.
Old Feb 16, 2005 | 11:47 AM
Evo348's Avatar
i installed the ams turbo back exhaust. Its a very nice fit, and the sounds is awesome. I really recommend it, fits just like the stock one.
Old Feb 16, 2005 | 12:59 PM
berkel's Avatar
Hey all,
As an alternative, you can disconnect the two fuses under the hood for a minute, then re-install them. This clears the ecu but you get to keep your radio presets and whatnot.
The fuse box is on the driver's side. The two fuses are in the legend with "engine icons". I believe one is 10 amps and one is 15, but double-check.
I popped the ic hose at the TB, and after reconnecting it my car wasn't running great. I double-checked all my connections and pulled these fuses. You'll notice that the next time you start your car, the idle will take awhile to settle down. Mine stayed high for a few days, but then it seems to relearn everything after a couple of days.
Thoughts?
FB
Old Feb 16, 2005 | 01:06 PM
MadMsheen's Avatar
I have disconnected the two fuses (conveniently placed in a yellow pull up holder for easy disconnect; factory). That did not reset my SES after sealing an exhaust leak before the O2 sensor, so I'm not sure if that resets the ECU. However, it does reset my clock and radio stations. To reset my ECU I had to remove the negative and positive terminals.
Old Feb 16, 2005 | 01:07 PM
Kwman's Avatar
lol...i knew i forgot something.
Old Feb 16, 2005 | 01:10 PM
bigjhoney's Avatar
I dont think removing both the negative and positive is necassary, just the negative should be fine, with no ground theirs no power!
Old Feb 16, 2005 | 02:14 PM
Jakeg97's Avatar
who doesnt ?
anu mod i do i always disconnect the battery to reset the ecu
Old Feb 16, 2005 | 02:29 PM
sleet's Avatar
I didn't reset mine to install my TBE, I guess it wouldn't hurt tho.
