cant get the boost right on MBC
Hey i just installed the buschur MBC on my evo. on the instructions it says to turn it counter clock wise to turn the boost down and clock wise to turn it up. when i turn it counter clock wise it seems as if the threaded bolt is getting looser and coming out more, and when i turn it clock wise it goes in more and gets tighter. my question is, the boost is going to 25lbs and then dropping to 20 and then more sometimes etc... which way do i turn it to make it less boost, either way ive tried isnt seeming to work?
Turning the screw counter clock wise should lower the boost. Is it installed correctly;
http://www.evotuners.net/forums/showthread.php?t=335
How far away from the wastegate is your MBC mounted?
