Turbotimer F'ing up coilpacks?
Old Feb 19, 2005 | 11:03 AM
RalliArtEvoVIII's Avatar
i read a thread on a guy stating that turbo timers ruin coil packs,etc..well it was weird.
i turned my key to the on position where my accessories and turbotimer come on, but the engine is off. well i had the hood open workin on somethin and i was next to the car and all of a sudden, i heard my coilpack or somethin goin nuts. like tick tick tick tick with a mix of zzz noises. so i figured it was the TT messin wit the coilpacks. should we continue to use turbo timers? I have ahks type 1 with the harness.
Old Feb 19, 2005 | 11:06 AM
plokivos's Avatar
that's reasonable assumption, considering the tt taps into the ignition when in 2 position before the ignition, then turns off again and on when you start the car.
i think the zzz noise is normal, i don't like the tick tick tick noise...
Old Feb 19, 2005 | 11:09 AM
i know the car makes a noise after u turn the car off, like a tick,zzz. sounds like coilpacks or somethin. its in the ingition area, but when i was next to the car, it was going nuts. it usually makes that noise once when the car turns off, but it was going tick tick tick zz z zz z z z z z z
Old Feb 19, 2005 | 11:15 AM
plokivos's Avatar
have you try starting your car after taking your TT out? I think that would be my next move/dialysis.
tt is simple to take out, mind as well.
Since you have to take it out anyway, if it's messing with your coil packs.
Old Feb 19, 2005 | 11:58 AM
mitsuorder's Avatar
I was told about a year ago by my dealer tech that the tic tic zzzzz sound is the idler motor at any rate mine make the same noise on occasion and I run a TT, an Apexi unit using the HKS ignition harness. My coil packs are still doing what they're supposed to be doing as far as I know, knock on wood.
Old Feb 19, 2005 | 12:48 PM
Ev0 1's Avatar
https://www.evolutionm.net/forums/sh...imer+coilpacks
Are you talking about that thread? I believe the problem was just Greddy's emanage and not the turbo timer but they fix the problem with the emanage.
Old Feb 19, 2005 | 02:25 PM
oh my car started. when ih ear the ticking noise, i took the key outta the ignition and turne the time off. when i was done with what i was doing, i started the car and it started fine. i was just worried about it making those noises.
Old Feb 19, 2005 | 03:26 PM
mitsuorder's Avatar
weird, so it was making the ticking buzz noise while it was running? sorry must have misunderstood.
Old Feb 19, 2005 | 04:33 PM
no, the key was turned on just so the accessories are on, and all the check lights on the cluster show up, but the engine was still off. accessories like the turbo timer, radio, power windows.
Old Feb 20, 2005 | 11:44 AM
sleet's Avatar
Turbotimers don't do anything, the Greddy e-manage was doing it but they fixed it, refer to that thread for a more detailed answer.
Ferp
Jul 11, 2016 08:07 PM
Clockwise
Aug 22, 2008 09:54 PM
Deca Auto
Jan 16, 2008 02:58 AM
sykou
Lancer Engine Tech
Oct 16, 2007 09:52 PM
Blue car
Nov 15, 2004 08:24 PM
