weapon r engine tampener
I guess you mean damper lol
First off, the weapon r damper does not use a fluid medium to dampen vibration/shcok; it uses plastic/rubber resistance. Since it is designed and fitted for use on our cars, its highly doubtful that you can find a hood or trunk shock that will fit (plus you would need the metal cast fittings to place under the engine mount and under the strut tower bar if you were going to mount it in that position)
