MR 6spd swap into an Evo 8?
Old Mar 28, 2005 | 08:35 AM
umiami80's Avatar
I actully think there is a benefit to using a 5 Gear system Vs a 6th. Taller gears and less shifting are great ESPECIALLY on the road. Look at STi Drivers constantly rowing just to stay in their band.
If I were you I would look to lower your Final Drive ratio, it is rather high like. 4.3-4.5. Drop it to like 3.73 and well you will have a TALL 5th, that is my unltimate goal.
Not 100% sure how to change the ration But I would rather that then a 6-speed for sure.
Old Mar 28, 2005 | 08:37 AM
inariv5573's Avatar
Originally Posted by Mivo
very true u can always order this also... http://www.norrisdesigns.com/ go to lancer evolution 4-8 then click new items then click the 4.111 longer gear ratio and vwala!
Ooo yet another idea!
Old Mar 28, 2005 | 08:42 AM
umiami80's Avatar
.111 Longer Gear Ratio
This product raises the overall gearing of any Evo 4-7 from either 4.529 or 4.875 to 4.111. The result of this is higher speeds for all five gears!
Cost is £999 Inc Vat
New GSR in gear speeds at 7500Rpm are as below
1st 48Mph
2nd 69Mph
3rd 96Mph
4th 130Mph
5th 177Mph
Models:
Evo 4,5,6,& 7
Available:
Now
Right here. If you have a properly tuned Evo making Power till 7500 or so, you will be FASTER. To bad it costs $2000 for the parts, Gawd Damnit.
Old Mar 28, 2005 | 08:45 AM
thor's hammer's Avatar
This is for Evo 4-7 not 8. It also changes lower gear ratios so the Evo will be even more of a dog from stand still.
How about adding some sound proofing if you don't like the noise? Really cheap compared to changing anything in the transmission.
Old Mar 28, 2005 | 08:47 AM
umiami80's Avatar
No and No, it'll fit the 8 and it'll make a modded Evo faster. Less shifting, more time in gear, probably better sooolup as there is more load on the engine.
Old Mar 28, 2005 | 09:00 AM
sgplancer's Avatar
My thoughts exactly. This is what the GT35 people should be looking at. More time in the gear, instead of always running out of gear before the turbo is making the 'real' power.
Would be nice to know if TRE or shepard was able to make something like this, and obviously for a lot less.
Old Mar 28, 2005 | 09:11 AM
Try starting in 2nd and you'll have much less shifting - more time in gear and terrible 0-60. Then shift from 2nd to 4th.....
What's needed is a taller top gear - not the whole range.
Spoolup has to do with exhaust gas flow = rpm - not engine load.
Old Mar 28, 2005 | 09:14 AM
osunick's Avatar
Originally Posted by inariv5573
That's strange, that's how fifth is on mine. So I guess the sixth gear doesn't help any. They just put the gears closer together it seems.
Yeah if you look at the gear ratios the sixth gear is slightly taller than our fifth but the final drive is slightly shorter, so it works out to be almost the same. The extra gear on the six speed fits sort of between where our fourth and fifth gears are. I never noticed a dead spot tehre so I wonder why they did it that way. On the Evo IX, the gearing is shorter to the point where you'd almost have to get the MR to have tolerable highway drone.
Old Mar 28, 2005 | 09:24 AM
chronohunter's Avatar
back on topic... does any one KNOW (no guesses please!) if you can put in the MR 6-speed gears only? In other words not have to add the ACD.
Old Mar 28, 2005 | 09:28 AM
lil'evil_evo's Avatar
Originally Posted by GEARS
Well how about 3000 @ 80mph? or 200mph @ 7500rpm?
I have it.
Who wants it?
Jon@TRE
send it my way
Old Mar 28, 2005 | 09:29 AM
NYREDEVO's Avatar
I have it.
Who wants it?
Jon@TRE
How much?
Old Mar 28, 2005 | 10:07 AM
umiami80's Avatar
You're an idiot. It makes you have more time in the gears. Having MORE power you would pull through them and have more time in them. I can all but Guarantee a Better 1/4 mile time with a HIGHER trap as you are in gear long putting power to the ground. Torque may slightly increase as your load is.
STOP TALKING NOW!!!!!!!!!!!!!!!!!!!!!!!!! Go sit in your car, rev it in Neutral and tell me HOW MUCH boost you make, load creates boost, sorry.
Old Mar 28, 2005 | 05:21 PM
4 years of engineering school down the drain. Thank god this web site can re-educate me...
Old Mar 28, 2005 | 05:41 PM
mhgsx's Avatar
I have it.
Who wants it?
Jon@TRE
How about just a slightly taller 4th gear?
Old Mar 28, 2005 | 09:15 PM
umiami80's Avatar
Sorry buddy, this one your wrong about. Especially with bigger turbo's that need more times to spool, you'll be in power band longer.
Stock, well yeah you gona be slower, having a 450WHP Evo well you'll just be faster, sorry.
