How to locate a boost leak....???
Old Mar 29, 2005 | 02:45 PM
BaLListic_EVO's Avatar
I keep having a boost leak about mmmm 6000rpm any ideas of how i could find out where its coming from???? could i possibly put somthing on the hoses to see if it bubbles up under boost or what.....
Old Mar 29, 2005 | 03:21 PM
matt55's Avatar
http://www.dsmtuners.com/forums/showthread.php?t=138569
Look at the 6th post , get something like this , put on turbo , pressurise , use soapy water to find leaks . It will leak through to motor but it slowley enuf to find what your looking for . good luck
Old Mar 29, 2005 | 04:37 PM
marksae's Avatar
http://www.vfaq.com/mods/ICtester.html
Old Mar 29, 2005 | 04:46 PM
WHTEVO's Avatar
good links. try them out and you'll find the leak.
Old Mar 29, 2005 | 05:34 PM
yeah i figured that soapy water would do the trick...
Old Mar 29, 2005 | 05:42 PM
Lancerguy'03's Avatar
so when the car is at idle to soapy water should bubble as well?? i also have a recirc BOV..so i cant build postive pressure...does that matter?
Old Mar 29, 2005 | 06:16 PM
marksae's Avatar
Bad idea! At idle, your intake system is under vacuum. If you have a leak and you spray water over the leak, the water will get sucked into the engine!
You really need to build an intake leak tester, then use an air compressor to pressurize the intake system. You'll be able to hear major leaks audibly. Once you narrow down the leak to a certain area, then spray soapy water over that area to pinpoint the exact location of the leak.
Old Mar 29, 2005 | 06:17 PM
ah, ok now i get it...thnx..duh.
Old Mar 29, 2005 | 07:08 PM
GOKOU's Avatar
DOn't quote me on this but it should be okay. I've clean my intake with water and use it without issues. Also if you have a tear it's going to get wet when it rains anyway.
Old Mar 30, 2005 | 04:46 AM
matt55's Avatar
As posted befor its a BAD IDED !!
Old Jun 15, 2005 | 05:18 PM
titaniumkingpin's Avatar
is the turbo inlet on a stock turbo a 2" or 3"??
Old Jun 15, 2005 | 09:20 PM
bigjhoney's Avatar
bump, curious for an answer also.
Old Jun 15, 2005 | 09:24 PM
Derek Baker's Avatar
I believe its a 2"
Old Jun 16, 2005 | 09:30 AM
yes, i found that it is a 2" inlet.
I just got done doing a pressure check and found that the plug off the intake nipple flew off and is leaking (the smaller nipple on the injen intake pipe).
I also found that air was leaking from the drain of my oil catch can. Could this have been my boost leak?
Old Jun 16, 2005 | 10:06 AM
bump
