Defi Oil Pres Gauge Install HELP!!!
hi guys finally today i got around to installing my Defi D oil Pres gauge and i used the 42Draft Designs fitting and everything fit Really Really well and i have all my connections correct and double and triple checked and when i fire up the car the gauge does nothing!? it lights up and everything but thier is no pressure range.... checked for leaks and everything is good....
i have it installed like in the how to section on the Hex bolt area removed it and placed it thier etc....
Please any help would be great!
evoisdream
evoisdream
Make sure you connected the oil pressure line to the control unit. Then connect the control unit to the gauge. I know this may seem stupid, but it is something I overlooked which turned out to be the problem. I had the sensor connected directly to the gauge. Yeah, I'm a dumbass
I dunno what to tell you bro.. Sorry I can't be of more help. Maybe someone else will see this thread. The car starts though right? So there is oil pressure, the gauge just doesn't read it?
i tapped both the ignition & power wire to my radios constant pwr wire(or the clocks wire if u can find it), there's a tech article on evoM's homepage that show you the clock wires
anything else?
