Ultimate Racing High Flow Cat
Old Apr 3, 2005 | 04:33 PM
highenuff14's Avatar
For those of you who are running the UR HFC, does the unit rattle?
I picked up a used one and when I received it, I could tell that there are some rattling between the core and the shell. After the installation, I can really hear it when the car is idling. Thanks...
Old Apr 3, 2005 | 04:36 PM
Vroompsh's Avatar
one of my buddy's has this cat and his works fine...you may want to put the car on a lift and look at the heat shield to make sure it isnt bent or loose, that could be your problem. If it's inside the actual unit, call UR and get a new one. They have great customer service, i have their cat delete pipe.
Old Apr 3, 2005 | 07:29 PM
PVD04's Avatar
I don't have a problem with the cat itself rattling, but I did have a problem with it hitting the heat sheild under the car when I first installed it. That made an awful rattling sound.
-Paul
Old Apr 5, 2005 | 10:08 PM
Thanks fellas,
I double checked the clearance and nothing is hitting or rubbing between the heat shield and the cat. Like I said, I bought it used, so I don't think UR is going to warranty it.
ManiakMik
Jan 9, 2007 09:52 AM
Blue Evo 8
Dec 12, 2005 06:02 PM
snoop
26
Oct 21, 2004 01:26 PM
evosevengsr
May 20, 2004 01:51 AM
Hellacious
Lancer Troubleshooting
Mar 13, 2003 01:41 PM
