Need HELP Asap w/boost not being held....
Old Apr 16, 2005 | 07:52 PM
MO_EVO8's Avatar
Well I dont really know what is going on, I have the 38mm Tial, 35r and tial BOV. I have the hose nipple on the side of the wastegate going to the side of the Manual Boost controller (Hallman Pro), and the top of the Manual Controler T'ed inbetween the boost line by the crankcase filter and the BOV. I tried this again with a normal basic boost controler, and the boost still wil not build. Until I start adjsuting it and then it spikes up high (26psi) and then falls back to wastegate pressure (14psi). Im running out of ideas so if you can help .......Thanks
Old Apr 16, 2005 | 07:57 PM
jj_008's Avatar
It sounds like your BOV maybe causing your issue. Try tapping it off the compressor housing.
Old Apr 16, 2005 | 08:01 PM
2evo8s's Avatar
bov might be not working correctly...
Old Apr 16, 2005 | 08:07 PM
MO_EVO8's Avatar
Pics.....of both the normal boost controller, and then me holding up the Hallman how it was set up. The set up was working just fine with the stock turbo. I dont think its the BOV..
Attached Thumbnails Need HELP Asap w/boost not being held....-boost-001.jpg   Need HELP Asap w/boost not being held....-boost-002.jpg
Old Apr 16, 2005 | 08:13 PM
jj_008's Avatar
Were you using the Tial with the stock turbo? Were you using a manual boost controller "T" in at the BOV w/ the stock turbo?
BTW, I am going through my own boost control nightmare w/ my XEDE right now. Also, I would love to know how that turbo spools up, since I have the same manifold.
Old Apr 16, 2005 | 08:24 PM
MO_EVO8's Avatar
I have th estage 3 cylinder ehad from BR, so that helps. It spools up good I think. Remember Im wonlt getting 14psi....lol. And yes the BOV was used w/ the stocker, adn it was T'ed in there also.
Old Apr 16, 2005 | 08:36 PM
jj_008's Avatar
Try hooking it up this way.
Old Apr 17, 2005 | 09:31 AM
MO_EVO8's Avatar
Any other suggestions?
Old Apr 17, 2005 | 02:30 PM
MO_EVO8's Avatar
Help...
Old Apr 17, 2005 | 03:01 PM
GTVEVO's Avatar
You need to tap the compressor housing or use this part to get a boost pressure source from the hot pipe so you can feed that directly to the bottom of the wastegate then you can use your controler inbetween the two or inbetween the wastegate.
http://www.atpturbo.com/Merchant2/me...egory_Code=FTG
Old Apr 17, 2005 | 03:03 PM
GTVEVO's Avatar
Instructions above state before throttle plate and right now you are not getting your pressure source before the throttle plate.
Old Apr 17, 2005 | 04:12 PM
MO_EVO8's Avatar
Thanks...GTVEVO....problem is solved.
Old Apr 19, 2005 | 03:16 PM
cruizinmax's Avatar
How did you end up fixing the problem?
soldave
Feb 8, 2013 03:26 AM
djevoawhp
Aug 12, 2006 01:18 AM
Z_Lancer_Man
May 2, 2006 08:40 AM
AfireINSIDE
Apr 6, 2006 05:34 AM
[Cyanide]
Aug 12, 2004 10:21 PM
