Springs and retainers bring it on
Originally Posted by zstryder
How much are spring/retainer installs? I was following that other thread where Revolver had discovered the HKS cams rubbing against the springs and retainers, causing what could be long term premature wear.
I don't have any springs/retainers on my HKS cams now, but I'd like to get them done eventually.. I have heard some crazy prices though (as some shops insist on pulling the entire head). Is it possible to do it without pulling the head?
Are HKS cams rubbing on the stock valves springs or after market? It can be done while the head is on but the champers needs to be pressured.. Only good shops can do it.
https://www.evolutionm.net/forums/sh...d.php?t=117752
Here you go. It is quite an interesting read, if you get through it all.
Originally Posted by justchil
These are removed during a cam/headstud install right? Just curious if there would be any extra labor charges on putting new spring/retainers during a cam install.
Nope they are not removed... There will be extra charge I am srure.
For installing valve springs and retainers, id say that a shop would charge a little more than they would for installing cams (just an estimate). The labor involved is a complete bit**....trust me, ive swapped out valve springs and retainers before. Again, i dont think its worth the trouble, but if u gotta have a crazy high redline, then go for it.
I think it's more of a "better safe than sorry" feeling, rather than having to do with performance, really. I'm sure installing these is a good alternative to paying for a new valvetrain, IF it is determined that the seal contact has negative long term effects.
Like I mentioned - I'm not installing these so I can increase my redlineIt has been discovered that there is contact with the valve seals regardless of the rpms (and any contact is BAD). Yes, if I had these installed, I could increase my redline, but my primary reason is not that, but rather, to save my valvetrain from getting worn down in the long term. I plan to drive this car into the dirt, so this would be a good precaution if you plan on having aftermarket cams.
And no, I don't have a turbo upgrade, but I do have HKS cams. If you read the thread I linked earlier, you'll understand what I'm talking about.
Originally Posted by statix
Can your rods/rod bolts handle going over 8000rpms safely??
