Should i get cams or alchy injection?
Old May 9, 2005 | 04:36 PM
Derekj03's Avatar
I want to know which will give me the best power and most performance. I would be getting 264/272 cams or alchy injection both with a new dyno flash.. My other mods are listed in my sig... Thanks
Old May 9, 2005 | 04:37 PM
1.8t's Avatar
I would go cams
Old May 9, 2005 | 04:46 PM
bigjhoney's Avatar
^^ x2
Old May 9, 2005 | 05:02 PM
Rudy's Avatar
I say cams should be first. You'll be happy. They make a huge power difference. I already have cams and thinking about the alki but I'm still not sure if it's worth the risk. I've heard a lot of good stories about them but I've also read some nasty stories.
Old May 9, 2005 | 05:35 PM
adamhw's Avatar
cams. one time install, no maintanence required, similar gains, less risk.
Old May 9, 2005 | 05:43 PM
scott88vr6's Avatar
Cams cams cams
Old May 9, 2005 | 05:49 PM
healthynine's Avatar
why not both?! but I would say cams. I did them, and I'm really happy. Still undecided about alky
Old May 9, 2005 | 06:03 PM
qbbraveheart's Avatar
definitely get cams 1st
Old May 9, 2005 | 06:25 PM
mobounce's Avatar
cizams...sorry..im from the hood
Old May 9, 2005 | 06:30 PM
Az3ar's Avatar
sadly I have to go with cams although I hate them... they make the idle go to **** but oh well we all need more power
Old May 9, 2005 | 06:32 PM
03BREvo8's Avatar
id get both.. they work great together
Old May 9, 2005 | 06:33 PM
03BREvo8's Avatar
my idle isnt ****.. its a lil lumpy but thats to be expected .. and its only 264/272
Old May 9, 2005 | 06:37 PM
Az3ar's Avatar
As I said its to be expected for sure. Is the idle rough? Yes it is I have heard every cam combo out there and they are all lumpy except 264/264. Can you pass emission with cams? No you cant. In my area a cop will pull me over if he or she hears my engine rumbles like a v8. It all depends on how you want your car to be. I am going with 280/280 but then again my EVO is not daily driver but for daily driver I don’t recommend anything beyond 264/264...
My opinion.
Old May 9, 2005 | 07:02 PM
mobounce's Avatar
my 264/264 is lumpy here and there... but tuned great oh well.
Old May 9, 2005 | 07:06 PM
Ted B's Avatar
Even 272s can be made to idle like a stocker and run butter smooth (been there, done that). It requires a set of adjustable cam gears and appropriate cam timing to do this. You'll give up a little spool, but it makes very good power. Given the same configuration, even 280s can be tamed in the same fashion.
Just FYI.
