Pressure reading is sometimes 0......on idle
Old May 15, 2005 | 10:36 PM
timzcat's Avatar
Nothing to do with it.
Low flow means when the ECU applies the EGR solenoid it is not seeing the required O2 change it is expecting. Probably a vacuum hose is loose or something.
EGR valve is under throttle body on manifold. Solenoid is on bracket on back of intake.
Old May 15, 2005 | 10:40 PM
SlowCar's Avatar
timzcat: I did a search today followed what others have done.....checked all the hoses around the area, all of them were tight.
Old May 15, 2005 | 10:45 PM
IEXCELR8's Avatar
put a new o2 sensor in.
Old May 15, 2005 | 10:56 PM
SlowCar's Avatar
You mean the 1st O2 sensor after the turbo??
Old May 15, 2005 | 11:10 PM
Blak94GSX's Avatar
I wasn't sure if you had it solved yet or not, but here is the solution:
There is a solenoid that sits between the intake manifold (pressure source) and the fuel pressure regulator. When the ECU senses a low coolant temperature it closes the solenoid to block the flow of vacuum to the FPR. This lack of vacuum raises the fuel pressure in the fuel rail to allow the engine to run a bit richer (basically an electronic choke) and also to raise the fuel rail pressure in hot conditions to reduce vapor lock issues upon hot restart.
It sounds like you have T-ed the boost gauge in to the vacuum hose AFTER the solenoid, meaning it is being affected by the solenoid. You want to T the boost gauge before the solenoid so it gets the vacuum/pressure directly from the intake manifold unaffected by the solenoid.
Some pictures:
-This is the place you want to put the T (circled in Green), note the T in the picture and the line it is on
http://www.evoporn.com/pics/boostgauge/boost_gauge.JPG
-Another view of the hose coming directly from the intake manifold
http://www.evoporn.com/pics/boostgauge/boost_gauge2.JPG
-The FPR hose after the Solenoid, not the place to put the T
http://www.evoporn.com/pics/boostgauge/boost_gauge3.JPG
Old May 15, 2005 | 11:20 PM
SlowCar's Avatar
Blak94GSX Thanks man! Thats was where i screwed up! A MILLION THANKS! I'll switch it tomorrow.
Old May 15, 2005 | 11:26 PM
Blak94GSX's Avatar
Sure, no problem.
Post back if it works so others searching can see the resolution.
Thanks
Old May 15, 2005 | 11:27 PM
SlowCar's Avatar
Originally Posted by Blak94GSX
Sure, no problem.
Thanks
Will Do! Thanks again!
Old May 16, 2005 | 08:37 AM
rraulston's Avatar
I just knew your couldnt run on 0 vacuum!!! I figured it was the gauge.......
