how do you know when you misfire?
Old May 23, 2005 | 09:37 AM
sirloin1219's Avatar
not sure if what this sound is..i just got my car new..and i have about 1500 on the engine so far..on the second oil change...so i was testing out the car got it to about 6.3 rpm...and then shifted to second. and then i hear a pop from the engine when i shift it..not sure what that sound is. anyways have any ideas?
Old May 23, 2005 | 09:40 AM
hotrod2448's Avatar
Do you have an aftermarket exhaust on the car? With my cat back I've noticed it will pop when off the gas while shifting. It's normal and not a misfire. If it is popping when you are on the gas and you can feel the engine stumble that is a miss.
Old May 23, 2005 | 09:41 AM
Silver05Bullet's Avatar
he's talking about the pop u hear coming from the rear when u shift at high rpms, almost all evos have it
Old May 23, 2005 | 09:45 AM
Kronik's Avatar
I don't notice a pop when I shift -- now I have heard a something similar to that when I hit the rev limiter....it's possible when you are shifting that you still have the throttle down....maybe??
Old May 23, 2005 | 09:52 AM
i hear the pop right after i let off the gas and press in the clutch..so then i guess it's a normal thing then..when i shift i let go of the throttle..power shifting is bad lol, i just dont like doing it. anyways..is there a reason for the pop though? would you say it's a good thing of a bad thing?
Old May 23, 2005 | 09:55 AM
Kronik's Avatar
I wouldn't say it's good or bad -- I would say it is as expected
tha'ts cool..nice to hear..i always thought it was a bad thing that's why. wasnt sure exactly why the popping was occuring.
Old May 23, 2005 | 10:07 AM
hotrod2448's Avatar
It's from the lack of back pressure and residual fuel hitting the hot exhaust and burning. In my car shifting slowly from 1-2 and 2-3 @ 5,000 rpm it can be a really loud POP.
Old May 23, 2005 | 10:09 AM
is there a fix for this problem? i mean do i need an aftermarket exhaust and/or fuel pump? to fix this problem? what can i do? or is this just with eevrything and can't be fixed..
Bernardio's Avatar
Typically you'd get a "service engine soon" indication on your dash if you misfire. I'm not sure if a single misfire will trigger this or if you need to hit a certain number of misfires. the code is something like PO300.
Now backfire from the exhaust is common with the evos, even stock ones.
Old May 23, 2005 | 10:10 AM
Warrtalon's Avatar
I personally have never experienced it in any gear at any time under any circumstances.
Old May 23, 2005 | 10:12 AM
well explain to me a backfire? i think that's what i could be hearing..and what causes a backfire? cause now that i think of it..i hear it more from the back of my car.
Old May 23, 2005 | 10:16 AM
hotrod2448's Avatar
That is a back fire. It is not a problem don't worry about it. It is simply unburned fuel vapor being burned in the catalytic converter when you let off the gas. If it were doing that when you were on the gas it would be a problem.
Old May 23, 2005 | 10:20 AM
ahh i see cool cool..that works for me..will i still get something like that with a turboback
Old May 23, 2005 | 10:25 AM
hotrod2448's Avatar
You should, it doesn't have to be the cat to light it off. Any part of hot exhaust should be enough. If you run a cat delete pipe you will most likely get fire out of the exhaust as well.
