Help!!, Might be a Fuel Cut...
Old Jun 11, 2005 | 04:49 PM
Turbolover's Avatar
im having the same problem. its in third gear between 4-5K. i installed a 255FP and helped the problem, but still there alittle. i think im hitting the fuel cut-off when my boost spikes.<21 or 22 psi> need tuning 2 improve problem and eventually get rid of it.
Old Jun 12, 2005 | 12:20 AM
binsquared's Avatar
is it possible for the plug's gap to mess up when its never been touched?
Most of the mods in my car have been running for months, except my down pipe and test pipe. This only started happening a few days after i installed my down pipe and test pipe.
Plugs and wires are stock...
My car just recently hit 30k miles around the same time this started happening. Do you think it has anything to do with that?
Old Jun 12, 2005 | 12:39 AM
GIsnickers's Avatar
Yeah,
see this thread.. https://www.evolutionm.net/forums/sh...d.php?t=136422
Hope it helps.
Old Jun 12, 2005 | 11:16 AM
binsquared's Avatar
wow...alright ill check that out..
Old Jun 13, 2005 | 08:51 PM
BlueFastEvoVIII's Avatar
should i get one step colder plugs? My mods are on my sig
Old Jun 15, 2005 | 12:06 PM
i still have the problem any help?
Old Jun 15, 2005 | 12:22 PM
EvoTech's Avatar
If it falls on it's face hard. It is fuel cut. Without a piggyback or a flash, there is no way to fix this other than taking your mods off. I would start with re-placing the intake with the stock airbox. A mail in flash would do wonders for you, but if you can't wait. put the stock box back on and see what happens.
Old Jun 15, 2005 | 06:26 PM
taenaive's Avatar
Hate that fuel cut! It happens to me when my engine is not warmed up and outside air is cold. It is fine on hot days or after my engine is warmed up. are you getting this even after engine gets hot?
Old Jun 16, 2005 | 12:57 PM
binsquared's Avatar
^yes i do..
I decided im gonna wait til I bring my car to AMS for installation and tuning and just have them fix the prob
Old Jun 16, 2005 | 01:52 PM
Wicked's Avatar
plugs plugs plugs
Old Jun 16, 2005 | 03:48 PM
im getting tuned july first and i want to change my plugs do you guys recomend a stage colder for my mods
Old Jun 16, 2005 | 10:53 PM
yellowman's Avatar
Check the plugs for sure, BUT WHATEVER YOU DO....DO NOT REGAP THEM. I JUST HAD TWO OF MINE BREAK (THE ELECTRODES).
THE SYMTOms sound identical to when I broke my electrodes
Old Jun 17, 2005 | 10:26 AM
anyone got any ideas on what plug i should run?
Old Jun 27, 2005 | 10:40 AM
binsquared's Avatar
I changed my plugs the other day and heres what happened...
after changing the plugs to NGK BPR7ES's, the CEL went away and i took the car out for a spin, and wow it was running fine, no more sputtering...
so i go for a quick shower, come came back turned my car on, and the CEL is back on. I take it out for another run and its fine. About 10 min into my drive, im at a stop, i go to 1st, and 2nd gear up to 6kRPMs no problem, but when I hit 3rd gear it started sputtering at 4.5kRPMs again...
After that its been sputtering every gear AGAIN...DAMMIT!!
so wtf?
Old Jun 27, 2005 | 06:33 PM
yea i still have the problem im going to buy plus and gap them to .024 or a lil lower to see of that helps the problem ill let u know
