Can someone take a picture of...
You know the front lower motor mount? Well I need to know if there is a sleeve through that mount, because the rubber mount is larger than the bolt, thus there'd be slack.
It is a guess but i am assuming the reason for the space is this: Almost all factory motor mounts are designed to wiggle a decent amount anyways, make the motor seem to run smoother, make shifts feel smoother and cause less stress on all the motor mounts combined. I would assume thier main reasoning was for a comfort mod... like the balance shafts; they arent needed but make it run "smoother". I would see no problem in making them stiffer but I would recommend trying to deduce where you would like the motor to sit more firmly. It may not matter but I would think you would want the least amount of an angle for the ring/pinion gear in the T-Case... I really dont know though.
- Steve
