Top speed for the stock turbo?
Old Jul 1, 2005 | 03:34 PM
housedj's Avatar
Question Top speed for the stock turbo?
any takers on this? last night i hit 165 in the '03. i had 1300rpms left b4 fuel cut so i think i can get 170. BTW this is on stock cams. of course my turbo looked like i pulled it out of Episode 3's lava scene!!! car was still pulling & the gauge was still reading 20PSI. with a 4G64 block, new ECU, & a 25G, 200mph should be around the corner.
Old Jul 1, 2005 | 03:36 PM
mrbkkt1's Avatar
you will need a new tranny/ diff gearing, i went 155 @ 6k rpm's in 5th, 170 is def doable w/ enough road.
Old Jul 1, 2005 | 04:38 PM
RKT SHP's Avatar
i have done 175 in my MR before(at least thats what the speedometer said). and it was still pulling. and i have still have the stock turbo
Old Jul 1, 2005 | 04:51 PM
en1gma19's Avatar
You can hit 200mph on the stock turbo. the turbo is not what limits your top speed. CD and gearing is more of a limiting factor. ASTROEVO has hit 191mph and I'm almost positive he is still using stock turbo.
Old Jul 1, 2005 | 05:00 PM
nnorris7413's Avatar
Damn, 191 mph on the stock turbo. Thats awesome....makes me love my car even more.
Old Jul 1, 2005 | 09:09 PM
propellerhead's Avatar
All on a closed road course, of course... :P
Old Jul 1, 2005 | 09:14 PM
Chris@nolimitmotors's Avatar
do u guys have your speed limiters removed??? Does teh reflash remove it??? it must because I just hit about 155 mph but i have 19" rims with 235/35/19 tires so if you do the math thats a lil over 160mph but stock the cars are governed at 156 mph from what i hear.
Old Jul 1, 2005 | 09:23 PM
2003evolution's Avatar
i went 165mph on open highway at 5900rpm
with stock turbo
JSYEVO's Avatar
the flash gets rid of it
Old Jul 2, 2005 | 12:16 PM
housedj's Avatar
i guess i'll need this gear set to lower my final drive ratio to 4.111...
Old Jul 2, 2005 | 06:42 PM
TrinaBabe's Avatar
TRE also makes a much longer final drive just so you know. Depends on what you use your car for but they would be another option to go with.
