Crankwalk?!?....wtf!!!!
Old Jul 7, 2005 | 04:11 PM
Zeus's Avatar
Get a second opinion!
Old Jul 7, 2005 | 04:21 PM
Evo8kid's Avatar
act 2600..
Old Jul 7, 2005 | 04:34 PM
badhabit90's Avatar
Cool crankwalk???!
i understood that the evo 8 clutch system is different from the DSM 2g system. the evo 8 has a PULL type of clutch instead of the PUSH type of clutch which would rapidly increase the chances of crankwalk. the push style would obviously push towards the crank instead of pull away like the evo 8 to engage the clutch. anyone?? i had this discussion on socalevo.net before and talked with Jeremy Sosa a Mitsubishi Master Tech ( screen name is DR EVO i believe).
Old Jul 7, 2005 | 05:32 PM
auto addictions's Avatar
How much power does you car make? and for how long on stock motor, Crank walk is poss. but very unlikly. Sounds fishy to mee too.
Old Jul 7, 2005 | 09:39 PM
USP45's Avatar
The 8 also uses the multi piece center bearing, not the one piece that supports the crank and serves as the thrust bearings. Maybe someone else needs to look at it.
Old Jul 7, 2005 | 11:27 PM
EVOONYOASS's Avatar
^^^I agree. Take it to the dealer, they will tell you the truth and do something about it.
Old Jul 7, 2005 | 11:45 PM
marksae's Avatar
Can't a pull-type clutch cause crankwalk also since it places an axial load on the crank, but in the opposite direction? Hmmm.. maybe I should disable my clutch start switch just as a precaution.
Old Jul 7, 2005 | 11:55 PM
nickracer9's Avatar
i don't believe the crankwalk issues have anything to do with what internal parts your useing. the problem could come from push type configurations and high clamp load pressure plates though. also this was not a problem for the dsm's that had auto trans.
Old Jul 8, 2005 | 12:19 AM
90GSX-03EVO's Avatar
Originally Posted by Evo8kid
yes..that is why im sooo surprised...i know crankwalk was only the 92.5 to 99 dsms....but we do have 7 bolts...
95-99 DSM's. It didn't become a problem when they switched over to the 7 bolt design, but when they started making the 4G63 in the US, which was in 95. The 1st Gen 7 bolt motors somply got different internals, (connecting rods, pistons, etc.). The 2nd Gens got the horrid bearings that were "matched" to suit the warped cranks.
Either way, it could be possible, since most cases of crankwalk showed up after people swapped in aftermarket clutches into their 2nd Gens which in turn would make the crankwalk process "speed up," if you will.
Old Jul 8, 2005 | 09:47 AM
Evo8kid's Avatar
thats exactly what the guy told me...the aftermarket clutch..since it has a harsher engagement..just sped it up and made it coem quicker....
Old Jul 8, 2005 | 09:51 AM
WrX Kila's Avatar
Get a second opinion.
Old Jul 8, 2005 | 10:01 AM
anjapower's Avatar
omfg
Old Jul 8, 2005 | 10:28 AM
WHTEVO's Avatar
like others have posted i would seriously get a second opinion. this is almost unheard of for evos and think you have a diefferent problem. verify it yourself that your crank blade is in fact hitting your crank angle sensor. you can also measure the end play from the crank pulley to your cover. just pry a little on the pulley away from the engine a vise versa and measure with a dial caliper of some sort. good luck.
Old Jul 8, 2005 | 10:30 AM
Curt@MrLed's Avatar
Former Vendor
something sounds fishy here.
Old Jul 8, 2005 | 11:09 AM
EvoTio's Avatar
Wow, this will suck if there are other cases of crankwalk in our Evos. I knew of several people in 2nd Gen DSM's that had to deal with this problem. I had a 94 1st Gen Talon Tsi and had over 70,000 miles without any problems.
