Stock turbo efficiency?
Old Jul 17, 2005 | 01:10 PM
mooreboost's Avatar
When speaking of the stock turbo's efficiency you are referring to it's ability to compress air while producing a given amount of heat, correct? So what PSI level does the turbo create the most power without creating so much heat that it negates any gains from boost? Also, what is a good PSI for an engine running methanol?
