EVO VII Throttle body leak,
Hi guys,
I found my engine idling a little a little ruff so we connected up the leak smoke machine tester and found the throttle body leaking air from the side closest to the engine. (See photos)
Wondering if anyone else has come across this problem and have an easy fix besides replacement?
Thanks.
Thanks.
Could be the throttle body shaft seal. Sometimes it will rear its head in higher mileage applications. VFAQ has this to say in relation to DSMs, but should carry over to the EVO:
http://www.plymouthlaser.com/tbor.htm
http://www.ca.dsm.org/faq/tb-shaftseals.html
You could try Mach V. But it seems like they're back ordered.
http://www.machv.com/throtbodseal.html
--Dan
Mach V
MachEVO.com
This sucks and to think MIT should have learn by now. I can see the engine blowing up with hassle from MIT.
I better go check mine because the other day it seemed like my throttle was slightly stuck open.
04whiteRS
Apr 6, 2015 08:18 AM
WTB[Northeast]: Ported Intake Manifold and Throttle Body
12WWGSR91
Jul 8, 2014 07:56 AM
Turbo Kyle
Aug 18, 2008 08:07 AM
