Porting stock turbo
Porting stock turbo
Has anyone ported there stock turbo.....and if you did how was the spool up and top end .......and how many awp did you get.......
I did minor porting on my exhaust components during my 10.5 hotside install.
I gasket matched the manifold to turbine housing junction. The turbine housing inlet required very little material removal. The manifold outlet required a little more material removal. Overall, it was still very minor.
I also gasket matched the turbine housing to o2 housing junction. I spent the most time porting the turbine housing outlet. The 10.5 hotside outlet's opening was slightly smaller than the stock 9.8 hotside.
This picture shows the area marked for material removal:
Here's how it looked after the porting. Not a very good pic.
The o2 housing required very little material to match the gasket.
Overall, I don't think the porting made much difference as the stock pieces are pretty well made to begin with. But if you have everything apart, you might as well clean things up a bit.
Originally Posted by trinydex
you should look into polishing too br i think claimed up to 12 hp, the spool increase is not definite.
Originally Posted by EvilBlueEvo8
what did you use to port it? dremel? die grinder?
yeah that's what i meant. the other surfaces inside obviously still have casting sandyness, not that there's dire need for it... but that's what br has done to his and that's what the white rabbit has done to it.
